/INISPRI/FULL
Block Format Keyword Describes the initial state for spring elements. All values defined in this card will be applied at the beginning on the computation.
/INISPRI/FULL/unit_ID | |||||||||
spring_ID | prop_type | nvars |
FX | DX | FEPX | DPLX+ | DPLX- | |||||
LX | EI |
LX | EI | DFS |
FX | DX | FEPX | |||||||
LX | EI | DV |
FY | DY | FEPY | DPLY+ | DPLY- | |||||
FZ | DZ | FEPZ | DPLZ+ | DPLZ- | |||||
MX | RX | MEPX | RPLX+ | RPLX- | |||||
MY | RY | MEPY | RPLY+ | RPLY- | |||||
MZ | RZ | MEPZ | RPLZ+ | RPLZ- | |||||
LX | LY | LZ | EI | EDX | |||||
EDY | EDZ | ERX | ERY | ERZ |
FX | DX | ||||||||
FY | DY | ||||||||
FZ | DZ | ||||||||
MX | RX | ||||||||
MY | RY | ||||||||
MZ | RZ | ||||||||
EI | |||||||||
V1 | V2 | VR3 | Vnvars |
unit_ID | Optional unit
identifier. (Integer, maximum 10 digits) |
spring_ID | Element
prop_type | Property set. 2 (Integer, maximum 10 digits) |
nvars | Number of user element
variables . (Integer, maximum 10 digits) |
FX | Spring element force
along X direction. (Real) |
[N] |
FY | Spring element force
along Y direction. (Real) |
[N] |
FZ | Spring element force
along Z direction. (Real) |
[N] |
MX | Spring element moment
around X direction. (Real) |
[Nm] |
MY | Spring element moment
around Y direction. (Real) |
[Nm] |
MZ | Spring element moment
around Z direction. (Real) |
[Nm] |
DX | Spring element
elongation along X direction. (Real) |
[m] |
DY | Spring element
elongation along Y direction. (Real) |
[m] |
DZ | Spring element
elongation along Z direction. (Real) |
[m] |
RX | Spring element
rotation around X direction. (Real) |
[rad] |
RY | Spring element
rotation around Y direction. (Real) |
[rad] |
RZ | Spring element
rotation around Z direction. (Real) |
[rad] |
FEPX | Spring elastic-plastic
force along X direction. (Real) |
[N] |
FEPY | Spring elastic-plastic
force along Y direction. (Real) |
[N] |
FEPZ | Spring elastic-plastic
force along Z direction. (Real) |
[N] |
MEPX | Spring elastic-plastic
moment around X direction. (Real) |
[Nm] |
MEPY | Spring elastic-plastic
moment around Y direction. (Real) |
[Nm] |
MEPZ | Spring elastic-plastic
moment around Z direction. (Real) |
[Nm] |
DPLX+ | Max displacement in
positive X direction. (Real) |
[m] |
DPLY+ | Max displacement in
positive Y direction. (Real) |
[m] |
DPLZ+ | Max displacement in
positive Z direction. (Real) |
[m] |
RPLX+ | Max rotation in
[m] |
RPLY+ | Max rotation in
[m] |
RPLZ+ | Max rotation in
[m] |
negative X direction. (Real) |
[m] |
negative Y direction. (Real) |
[m] |
negative Z direction. (Real) |
[m] |
[rad] |
[rad] |
[rad] |
LX | Spring length along X
direction. (Real) |
[m] |
LY | Spring length along Y
direction. (Real) |
[m] |
LZ | Spring length along Z
direction. (Real) |
[m] |
EDX | Deformation energy
[J] |
EDY | Deformation energy
[J] |
EDZ | Deformation energy
[J] |
ERX | Rotation energy around
[J] |
ERY | Rotation energy around
[J] |
ERZ | Rotation energy around
[J] |
DFS | Relative force between
pulley branches. 2 (Real) |
[N] |
DV | Spring velocity
filtering. 3 (Real) |
[ms] |
EI | Total internal
energy. (Real) |
[J] |
VR1 | 1st user
variable value. (Real) |
VR2 | 2nd user
VR3 | 3rd user
Vnvars | nvarsth user variable value.
4 (Real) |
- The initial state for spring may be defined by more than one block (for the same spring type only).
- The relative force between pulley branches, DFS, is available only for spring property /PROP/TYPE12 (SPR_PUL).
- Spring velocity filtering, DV, is available only for spring property TYPE26. It is based on strain rate filtering factor (ALPHA – see /PROP/TYPE26 (SPR_TAB)).
- The nvars is the number of the first user variables to be initialized for a spring. It must be less or equal to the total number of internal variables used in a user type law (NUVAR).
