/SENSOR/TIME
Block Format Keyword Describes the sensors used to activate or deactivate an object according to time delay.
| /SENSOR/TIME/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | Optional unit
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time
delay. (Real) |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- For Sensor type TIME, the sensor is activated after the time delay Tdelay. Tdelay is not applicable with the force based sensors type RWALL, INTER, RBODY, WORK or SECT.
