Application definitions are a predefined set of instructions to describe application parameters, store responses and
prepare responses for job execution.
Add and connect to Access Web server using HTTPS to
submit and monitor jobs.
You will need the URL of an Access Web server as well as
a valid set of credentials to add a cluster via HTTPS. All communication between
Access Desktop and Access Web is
encrypted.
Open the Windows system tray.
Double-click the Access Desktop icon .
Click .
Select Clusters.
A Clusters dialog box is displayed.
Select HTTPS from the drop-down list.
Figure 1. Adding a Cluster
Enter a Cluster Display Name.
Note: You can use alphanumeric characters for a cluster
display name.
Enter the Access Web URL in the format
https://<hostname>:4443. Hostname is the machine
where Access Web is installed.
Note: If a hostname is provided during the Access Web installation enter the Access Web URL using the hostname to register the
HTTPS cluster. Similarly follow the same if IP address is provided.
Click Add.
A new web browser is launched and authenticates the user using the
OpenID Connect (OIDC) and provides an authenticate code. Figure 2. OIDC Authentication
Click Submit.
The Access login page is displayed.
Enter your credentials.
Figure 3. Access Web Login
Click Log In.
Figure 4. Successful Login
Close the browser. Return to the Access Desktop application; the
cluster is added, and a green check mark is displayed next to the cluster
name.
Figure 5. HTTPS Cluster Register
Tip: Repeat the steps to add an additional
HTTPS cluster.
