Add a New Role
Create a custom role for your site.
Review the default roles and privileges before adding a new role.
  1. Click > Access Management.
  2. Click Roles from the Access Management menu located on the left-hand side of the web page.
  3. Click Add Role.
    A role is created with a default role name and undefined privileges.
  4. Click located to the right of the name of the role.
    1. For Role Name, enter a name that describes the role.
    2. Click OK.
  5. Choose System Administrator privilege if you want to provide full permission.
    By default, only Application User privilege is provided to the new Role.
  6. Click at the top next to the Assigned Resources.
    The Available Resources menu is displayed.
  7. Choose the resources to give to this role by clicking the check-box located to the right of the resources.
    Resources are not mutually exclusive, so you may assign more than one.
  8. Click Ok in the Available Resources menu.
  9. Click Save.
    The new role is displayed in the Roles list.
