Assignment of regions: completion and modification modes
Assign a region (completion mode)
To assign a face (volume) region to the faces (volumes) using the completion mode:
Step | Action |
1 |
Activate the command:
→ | An assignment box is open. |
2 |
Fill out the fields in the assignment box:
3 |
Validate the information:
→ | The region is assigned to geometric entity; the entity concerned is made invisible. |
→ | An assignment box is automatically open. |
4 | Repeat these operations (steps 2 et 3) until the group of faces is assigned to the face regions (or the group of volumes is assigned to the volume regions) |
Visibility of geometric entities
In the completion mode, the visibility of geometric entities makes easy the assignment process.
During the assignment process:
The faces (or volumes) are made invisible during their assignment. Only the items that do not belong yet to a region are visible in the graphic area.
After the assignment process:
The faces (or volumes) are again visible. One of the following messages informs the user that the assignment process is complete.
*** No entity for assignRegionToFaces ***
*** No entity for assignRegionToVolumes ***
Assign a region (modification mode)
To assign a region (volume, face, line or point region) to geometric entities (volumes, faces, lines or points) using the modification mode:
Step | Action |
1 |
2 |
3 |
→ | The region is assigned. |
4 |
Quit the sequence:
Modify the affiliation of a geometric entity
To modify the affiliation of a geometric entity to a region, it is also possible to directly modify this geometric entity.
For each entity type (Point, Face, Line and/or Volume), this type of modification is described in the correspondent section and summarized in the table below.
Step | Action |
1 | Open the properties sheet of the desired geometric entity (volume, face, line or point) |
2 | Select the Region tab |
3 | Choose the desired region from the proposed list |
The NONE option (blank space) in the list of proposed regions allows us to assign no region to the corresponding geometric entity.
