Multiphysics commands for data update, import and export
Description of commands
The descriptions of the multiphysics commands for data updating, import and export to implement the data exchange process are presented in the table below:
| Commands | Description |
| Export coordinates of regions nodes |
                         Permits to export the coordinates of regions nodes of a Flux problem to a (DEX) type file Initial conditions: meshed problem. Output: a file containing the coordinates of the selected region nodes.  |
| New multipoint support by importation of a list of points |
                         Permits to create a multipoint support by importation of a points list originating from another problem in view of preparing the exchange between the two problems of a different nature. Input: a file containing the points coordinates Output: a multipoint support containing the imported points.  |
| Export spatial quantity and formula starting from different types of supports |
                         Permits to export a spatial quantity or a formula of the nodes of a support to a (DEX) type file. Input: the quantity to be exported. Output: a file containing the nodes of the chosen support and the values of the chosen quantity for each of these nodes.  |
| Update multiphysics spatial quantity by importation |
                         Permits to update a spatial quantity of the multiphysics type by import of a file containing the values of the quantity in each node. The spatial quantity is necessarily created beforehand and necessarily of the multiphysics type. Input: the quantity to be updated, a file comprising the coordinates of the nodes and the values of a quantity corresponding to each of these nodes. Output: the updated multiphysics chosen spatial quantity.  |
| Update current value of an I/O multiphysics parameter |
                         Permits the update of the current value of an I/O multiphysics parameter before the resolution of one step. Input: the I/O parameter to update Output: the I/O parameter updated with the chosen value.  |
