Export of a spatial quantity and formula
Introduction
The user has the possibility to export the values of a spatial quantity or formula :
  • multipoint support
  • volume or surface region
  • 2D or 3D grid
Option regarding localization
The user can choose to filter the support points chosen by specifying the region where the calculus points must be found.
Thus only the calculi of the points belonging to the specified region will be exported.
Export format
A spatial quantity / formula from a support can be exported to a file which different format available are:
Format Description
*.DEX
DEX = Data EXchange
format specific to Flux
*.NAS Nastran format for AcuSolve
*.IP IP is a format for the Fluent software
*.VTK VTK is readable by StarCCM+
PyFlux output
Export spatial quantity/ formula
To export a spatial quantity/formula :
Step Action
1
In the menu Parameter/Quantity:
  • point on Export quantity
  • activate the command Export spatial quantity and formula
→ A dialog box « Export spatial quantity and formula » is opened
2
Choose the support for the export:
  • Choose the type of the support (multipoint, region, grid)
  • Choose the support
3
Specify the file to export:
  • choose the format (DEX, IP, ...)
  • choose the file
4 Choose the position of the mechanical set (if any)
5 Choose the spatial formula of the quantity to be calculated and exported
6 Validate by OK
