Update of the current value of a multiphysics I/O parameter
Introduction
During a multiphysics session, the user can update the current value of a multiphysics I/O parameter.
This value will be taken into consideration for the calculus of the next step.
The update is done by means of the command Update current value of a multiphysics I/O parameter.
Condition
To be able to update the current value of a multiphysics I/O parameter the current step must be put at zero or initialized.
Update of current value of an I/O parameter
To update the current value of a multiphysics I/O parameter:
| Step | Action |
| 1 |
                         In the menu Parameter/Quantity:
| → | A dialog box «Update current value of a multiphysics I/O parameter» is opened |
| 2 | Choose the multiphysics I/O parameter to be updated |
| 3 | Introduce the current value of the parameter to be applied |
| 4 | Validate by OK |
