Cut of electric loop: about (1)
Context
A cut of electric loop is introduced in a model when there is a need to solve an electric connectivity problem (in 3D).
Connectivity problem
Connectivity problem:
The coupling between the different potentials (formulations) is sometimes forbidden in the sense that the hypotheses allowing this coupling are no longer valid.
We are talking about electric connectivity problem in case of a closed electric loop with non-simply connected objects (see following blocks).
Notion of Connected space
Concept of cut
Electric connectivity problem
With symmetry or periodicity ...
