Modification/characterization of the electric circuit in the circuit editor context
Introduction
The procedures of modification and characterization are identical. First select is required and then edit the desired element.
Modifying/ characterizing a component of the circuit
To Modify or characterize a component of the circuit in the circuit editor*:
Step Action
1 Select the desired component*
2 Edit or Edit array the component
→ The dialogue box corresponding to the component is opened.
3
Modify the information in the dialogue box:
  • choose the desired tab (available tabs only for the elements of component type)
  • enter the desired information in the corresponding zones
4
Validate the information :
  • click on OK
→ The component has been characterized/modified.
Note: * possibility of modifying at the same time several components of the same type by using the Edit array command
