Entity selection: Circumstances and selection modes
Introduction
The most part of actions for handling the entities require the selection of entities .
Indeed:
  • to modify the coordinates of a point, you should select the corresponding point
  • to add a line (segment), you should define extremity points and then select starting point and ending point
The different selection circumstances and selection modes are presented in this paragraph.
Selection circumstances: overview
Selection of entities could be done before or after the activation of a command; it could also be done, during an operation of creation.
These various circumstances of selection are presented through examples in the table below.
Selection before activation of a command
… Activation of a command:
  • Edit
  • Edit array
  • Delete
  • Force delete
Selection after activation of a command (via selection box)
  • Edit
  • Edit array
  • Delete
  • Force delete
Selection during an operation of creation
  • New
Selection modes: overview
Selection of entities could be done with the following different selection modes:
  • graphic selection (directly with the mouse)
  • in the data tree for all entities
  • in the graphic area for graphic entities
  • identifier selection (by name / by number )
  • criterion selection* (by relation / by … identical characteristics )
* the advanced selection is detailed in § Entity selection: Selection by criterion
Summary
The different selection modes proposed function of selection circumstances are gathered in the table below.
Selection circumstances … Selection modes
Selection before
  graphic
Selection after
Selection box
graphic
by identifier (name/number)
by criterion
Selection during
Specialized box
graphic
