BODY_FORCE
Specifies a collection of volumetric body force terms.
AcuSolve Command
BODY_FORCE("name") {parameters...}
Qualifier
User-given name.
- gravity or grav (string)[=none]
- User-given name of the gravity command. If none, no gravity is included.
- rotation_force or rot (string) [=none]
- User-given name of the rotational force command. If none, no rotational force is included.
- mass_heat_source (string) [=none]
- User-given name of the heat source per unit mass command. If none, no mass heat source is included.
- momentum_source (string) [=none]
- User-given name of the momentum source command. If none, no momentum source is included.
- volume_heat_source (string) [=none]
- User-given name of the heat source per unit volume command. If none, no volume heat source is included.
- mass_species_1_source (string) [=none]
- User-given name of the species source per unit mass command for the species 1 equation. If none, no mass species source for the species 1 equation is included.
- mass_species_2_source (string) [=none]
- User-given name of the species source per unit mass command for the species 2 equation. If none, no mass species source for the species 2 equation is included.
- mass_species_3_source (string) [=none]
- User-given name of the species source per unit mass command for the species 3 equation. If none, no mass species source for the species 3 equation is included.
- mass_species_4_source (string) [=none]
- User-given name of the species source per unit mass command for the species 4 equation. If none, no mass species source for the species 4 equation is included.
- mass_species_5_source (string) [=none]
- User-given name of the species source per unit mass command for the species 5 equation. If none, no mass species source for the species 5 equation is included.
- mass_species_6_source (string) [=none]
- User-given name of the species source per unit mass command for the species 6 equation. If none, no mass species source for the species 6 equation is included.
- mass_species_7_source (string) [=none]
- User-given name of the species source per unit mass command for the species 7 equation. If none, no mass species source for the species 7 equation is included.
- mass_species_8_source (string) [=none]
- User-given name of the species source per unit mass command for the species 8 equation. If none, no mass species source for the species 8 equation is included.
- mass_species_9_source (string) [=none]
- User-given name of the species source per unit mass command for the species 9 equation. If none, no mass species source for the species 9 equation is included.
- volume_species_1_source (string) [=none]
- User-given name of the species source per unit volume command for the species 1 equation. If none, no volume species source for the species 1 equation is included.
- volume_species_2_source (string) [=none]
- User-given name of the species source per unit volume command for the species 2 equation. If none, no volume species source for the species 2 equation is included.
- volume_species_3_source (string) [=none]
- User-given name of the species source per unit volume command for the species 3 equation. If none, no volume species source for the species 3 equation is included.
- volume_species_4_source (string) [=none]
- User-given name of the species source per unit volume command for the species 4 equation. If none, no volume species source for the species 4 equation is included.
- volume_species_5_source (string) [=none]
- User-given name of the species source per unit volume command for the species 5 equation. If none, no volume species source for the species 5 equation is included.
- volume_species_6_source (string) [=none]
- User-given name of the species source per unit volume command for the species 6 equation. If none, no volume species source for the species 6 equation is included.
- volume_species_7_source (string) [=none]
- User-given name of the species source per unit volume command for the species 7 equation. If none, no volume species source for the species 7 equation is included.
- volume_species_8_sourcenone (string) [=none]
- User-given name of the species source per unit volume command for the species 8 equation. If none, no volume species source for the species 8 equation is included.
- volume_species_9_source (string) [=none]
- User-given name of the species source per unit volume command for the species 9 equation. If none, no volume species source for the species 9 equation is included.
BODY_FORCE commands collect
- GRAVITY
- ROTATION_FORCE
- MASS_HEAT_SOURCE
- MOMENTUM_SOURCE
- VOLUME_HEAT_SOURCE
- MASS_SPECIES_SOURCE
- VOLUME_SPECIES_SOURCE
GRAVITY( "my gravity" ) { ... }
ROTATION_FORCE( "my rotation force" ) { ... }
MOMENTUM_SOURCE( "my momentum source" ) { ... }
MASS_HEAT_SOURCE( "my heat source" ) { ... }
MASS_SPECIES_SOURCE( "my species source 1" ) { ... }
MASS_SPECIES_SOURCE( "my species source 2" ) { ... }
BODY_FORCE( "my body force" ) {
gravity = "my gravity"
rotation_force = "my rotation source"
momentum_source = “my momentum source”
mass_heat_source = "my heat source"
mass_species_1_source = "my species source 1"
mass_species_2_source = "my species source 2"
mass_species_3_source = "my species source 1"
}ELEMENT_SET( "fluid with body forces" ) {
body_force = "my body force"
}For backward compatibility with AcuSolve version 1.6 and earlier, heat_source may be used instead of mass_heat_source and species_1_source may be used instead of mass_species_1_source, and so on. However, these aliases are obsolete and will be deprecated in the future.
Both mass_heat_source and volume_heat_source may be specified in a single BODY_FORCE command. Similarly, both mass and volume versions of the species source terms may be specified simultaneously. The appropriate terms are simply added together. However, this usage is not recommended.
