VOLUME_SPECIES_SOURCE
Specifies species source per unit volume for a species transport equation.
AcuSolve Command
VOLUME_SPECIES_SOURCE("name") {parameters...}
Qualifier
User-given name.
- type (enumerated) [=none]
- Type of volume species source.
- none
- No volume species source.
- constant or const
- Constant volume species source. Requires volume_species_source.
- piecewise_linear or linear
- Piecewise linear curve fit. Requires curve_fit_values and curve_fit_variable.
- cubic_spline or spline
- Cubic spline curve fit. Requires curve_fit_values and curve_fit_variable.
- user_function or user
- User-defined function. Requires user_function, user_values and user_strings.
- volume_species_source (real) [=0]
- The constant value of the volume species source. Used with constant type.
- curve_fit_values or curve_values (array) [={0,0}]
- A two-column array of independent-variable/species-source data values. Used with piecewise_linear and cubic_spline types.
- curve_fit_variable or curve_var (enumerated) [=temperature]
- Independent variable of the curve fit. Used with
types.
- x_coordinate or xcrd
- X-component of coordinates.
- y_coordinate or ycrd
- Y-component of coordinates.
- z_coordinate or zcrd
- Z-component of coordinates.
- x_reference_coordinate or xrefcrd
- X-component of reference coordinates.
- y_reference_coordinate or yrefcrd
- Y-component of reference coordinates.
- z_reference_coordinate or zrefcrd
- Z-component of reference coordinates.
- x_velocity or xvel
- X-component of velocity.
- y_velocity or yvel
- Y-component of velocity.
- z_velocity or zvel
- Z-component of velocity.
- velocity_magnitude or vel_mag
- Velocity magnitude.
- pressure or pres
- Pressure.
- temperature or temp
- Temperature.
- eddy_viscosity or eddy
- Turbulence eddy viscosity.
- kinetic_energy or tke
- Turbulence kinetic energy.
- velocity_scale or tvel
- Transition velocity scale.
- dissipation_rate or teps
- Turbulence dissipation rate.
- eddy_frequency or tomeg
- Turbulence frequency.
- intermittency or tintc
- Transition intermittency.
- transition_re_theta or treth
- Transition Re-Theta.
- eddy_frequency or tomega
- species_1 or spec1
- Species 1.
- species_2 or spec2
- Species 2.
- species_3 or spec3
- Species 3.
- species_4 or spec4
- Species 4.
- species_5 or spec5
- Species 5.
- species_6 or spec6
- Species 6.
- species_7 or spec7
- Species 7.
- species_8 or spec8
- Species 8.
- species_9 or spec9
- Species 9.
- mesh_x_displacement or mesh_xdisp
- X-component of mesh displacement.
- mesh_y_displacement or mesh_ydisp
- Y-component of mesh displacement.
- mesh_z_displacement or mesh_zdisp
- Z-component of mesh displacement.
- mesh_displacement_magnitude or mesh_disp_mag
- Mesh displacement magnitude.
- mesh_x_velocity or mesh_xvel
- X-component of mesh velocity.
- mesh_y_velocity or mesh_yvel
- Y-component of mesh velocity.
- mesh_z_velocity or mesh_zvel
- Z-component of mesh velocity.
- mesh_velocity_magnitude or mesh_vel_mag
- Mesh velocity magnitude.
- user_function or user (string) [no default]
- Name of the user-defined function. Used with user_function type.
- user_values (array) [={}]
- Array of values to be passed to the user-defined function. Used with user_function type.
- user_strings (list) [={}]
- Array of strings to be passed to the user-defined function. Used with user_function type.
- multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the volume species source. If none, no scaling is performed.
VOLUME_SPECIES_SOURCE( "my species source" ) {
type = constant
volume_species_source = 10
BODY_FORCE( "my body force" ) {
volume_species_1_source = "my species source"
ELEMENT_SET( "fluid with species source" ) {
body_force = "my body force"
This example defines a constant volumetric species source per unit volume. Positive values add species to the system, while negative values remove species from the system.
A constant volume species source applies a spatially uniform volumetric species source per unit volume, as in the above example.
VOLUME_SPECIES_SOURCE( "curve fit species source" ) {
type = piecewise_linear
curve_fit_values = { 0., 0. ;
1., 1. ;
2., 4. ; }
curve_fit_variable = species_1
defines a species source as a function of the first species. The curve_fit_values parameter is a two-column array corresponding to the independent variable and the species source values. The independent variable values must be in ascending order. The limit point values of the curve fit are used when curve_fit_variable falls outside of the curve fit limits.
0. 0.
1. 1.
2. 3.
curve_fit_values = Read( "species_source.fit" )
A volume species source of type user_function may be used to model more complex behaviors; see the AcuSolve User-Defined Functions Manual for a detailed description of user-defined functions.
VOLUME_SPECIES_SOURCE( "UDF species source" ) {
type = user_function
user_function = "usrSpeciesSourceExample"
user_values = { 1.0, # constant coef.
0.5, # linear coef.
0.1 } # quadratic coef
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE( usrSpeciesSourceExample ) ; /* function prototype */
Void usrSpeciesSourceExample (
UdfHd udfHd, /* Opaque handle for accessing data */
Real* outVec, /* Output vector */
Integer nItems, /* Number of elements */
Integer vecDim /* = 1 */
Integer elem ; /* an element counter */
Real coef0 ; /* constant coefficient */
Real coef1 ; /* linear coefficient */
Real coef2 ; /* quadratic coefficient */
Real* spec ; /* species vector */
Real* usrVals ; /* user values */
udfCheckNumUsrVals( udfHd, 3 ) ; /* check for error */
usrVals = udfGetUsrVals( udfHd ) ; /* get the user vals */
coef0 = usrVals[0] ; /* get coef */
coef1 = usrVals[1] ; /* get coef 2 */
coef2 = usrVals[2] ; /* get coef 3 */
spec = udfGetElmData( udfHd,UDF_ELM_SPECIES ) ; /* get the species */
for ( elem = 0 ; elem < nItems ; elem++ ) {
outVec[elem] = coef0
+ coef1 * spec[elem]
+ coef2 * spec[elem] * spec[elem] ;
} /* end of usrSpeciesSourceExample() */
The dimension of the returned volume species source vector, outVec, is the number of elements.
VOLUME_SPECIES_SOURCE( "ramped species source" ) {
type = constant
multiplier_function = "ramped"
MULTIPLIER_FUNCTION( "ramped" ) {
curve_fit_values = { 0, 0 ; 10, 1 }
curve_fit_variable = time_step
