ANSYS Interface 2022.1 Release Notes
Altair HyperMesh
Enhancements
- Unblocked format supported in import for Materials, Real Block, Loads, Constraint equations, and Systems.
 - Blocked format support for import of Pressure Load and Temperature Load.
 - Contact surface migrated to set segment entity.
 - Embedded Entity Editor support for contacts, Loadsteps, and set segments.
ANSYS Interface
Resolved Issues
- Edge selection does not work while spherical clipping is on.
 - Updating the pressure direction changes the magnitude of the pressure.
