LS-DYNA Interface 2022.1 Release Notes
Altair HyperMesh
New Features
- New LS-DYNA R13.0 Profile
 - The new LS-DYNA profile is introduced to support the new solver version R13.0.
 - New Systems Workflow
 - The new Systems workflow provides a interactive and efficient user
                            experience for the creation of coordinate systems.
Figure 1. - Import of Compressed Input Decks
 - It is now possible to directly import a compressed input deck.
Only the format .gz is supported.
 - New Material Behaviors Entity
 - The new Material Behaviors entity is used for the definition of *MAT_ADD
                            keywords, previously mapped to the Property entity.The Material Behaviors are also directly referenced into all *MAT keywords.
Figure 2. - New Constraints Entity
 - The new Constraints entity is used for the definition of
                            *CONSTRAINED_INTERPOLATION_SPOTWELD keyword.
Figure 3.
Enhancements
- Solver Profiles Cleanup
 - The LS-DYNA profiles R6.1 and R7.1 are no longer exposed.
 - Panels and Panel Functionality Removal in HyperWorks
 - Panels or panel functionalities for which an equivalent tool or workflow exists in other areas of the product (example: Browsers, Graphical entity selection, ...) are removed from HyperWorks only.
 - New Calculation methods for 2D minimal mesh size criteria
 - The minimal size calculation is enhanced by the addition of the LS-DYNA
                            specific methods ISDO=1 and ISDO=2.
Figure 4. - New Supported Keywords
 - *BOUNDARY_PRESCRIBED_FINAL_GEOMETRY
 - Updated Keywords
 - *CONTROL_CPM, *CONTROL_ENERGY, *CONTROL_IMPLICIT_SOLUTION, *CONTROL_MAT, *CONTROL_SHELL, *CONTROL_SOLID, *CONTROL_SOLUTION, *CONTROL_SPH, *CONTROL_TIMESTEP
 - Model Checker
 - Check added to report a warning when a *CONSTRAINED_NODAL_RIGID_BODY is defined with a massless independent node.
Resolved Issues
- *DEFINE_TRANSFORMATION applied on multiple nested *INCLUDE_TRANSFORM are now correctly calculated.
 - *SET_NODE and *CONSTRAINED_NODAL_RIGID_BODIES are now maintained in respective include on export.
 - Keywords titles containing special characters like "," are now fully read.
 - HM_TAGS defined in input decks are now read correctly.
 - Correction in finding unused Systems.
 - Correction in reading *DEFINE_CURVE when DATTYP attribute is blank.
LS-DYNA Interface
Enhancements
- Reader Enhancements
- Support of NVH / Frequency output files (D3PSD, D3RMS, D3FTG, D3SSD).
 - Plotting of Strain Energy Density is enabled.
Resolved Issues
- Issue when selecting a LS-Dyna model file containing *NODE_TRANSFORM as Model in is fixed.
Altair HyperGraph
Post-processing Enhancements
- Support for NVH/Frequency output files (frf_amplitude, frf_angle).
Resolved Issues
- Plotting elout history curves from a previously saved session file works.
