OptiStruct Interface 2022.1 Release Notes
Altair HyperMesh
New Features
- Automatic method to define a free convection setup
- New bulk cards CONVG and CNVGADD added to define free convection and combined free convection, respectively.
 - Subcase dependent free convection are defined with CONVG subcase selection cards.
 - Free convection definition can be created from Solver Browser.
 - CAFLUID-based flow heat transfer
- New element CAFLUID added as 1D element entity in Rod config.
 - New property PAFLUID to define 1D CAFLUID heat flow element.
 - CACONV bulk card added to group entity to define interface for forced convection heat transfer using CAFLUID.
 - Adaptive Perfectly Matched Layer(APML) for exterior acoustics
- New element types CACPML3 and CACPML4 to define APML element with triangular and quadrilateral base, respectively.
 - PACPML to define properties for APML elements.
 - Pressure penetration load to simulate fluid penetrating through the surfaces on a contact interface
- New bulk card PRSPENE to define pressure penetration load.
 - PRSPENE loads can created from Solver Browser.
 - OptiStruct specific PRSPENE checks are added in model checker.
 - Shell to Solid connection
- RSSCON1 bulk card added to define connection between shell and solid elements.
 - RSSCON1 is mapped to group entity.
 - SENSOR input to activate loads
- New bulk cards SENSOR to define sensor input.
 - SENSRAD bulk card to defined union of several sensor inputs.
 - Subcase references of SENSOR and SENSRAD are defined through SENSOR in subcase information entry.
 - Modal damping as a tabular function of mode index
- New bulk card TABDMP2 to define modal damping as a tabular function.
 - TABDMP2 card is mapped to curve entity.
 - MEFFMASS output in HyperMesh set based format
 - MEFFSET bulk card to group element sets to output MEFFMASS output in set based format.
 - Fatigue process manager template
- Option to write all fatigue cards into an include file.
 - Seam and Spot weld options are now enabled for EN fatigue method.
 - FKM2 option for Seam and Spot weld.
 - Import option to handle preserved nodes
Figure 1. - Section Property tool for VABS
- Generates VABS *dat file from intersection of plane with Shell composites.
 - Updates 1D beam with PBEAML property using VABS *.dat file.
 - Limited to OptiStruct interface.
 - 1D meshing consolidation
 - Consolidated 1D beam tools and Marine Stiffener meshing.
 - Beam → Solid
 - New tool to create Solids from 1D beam with standard beamsection.
Enhancements
- Pre-tension manager now allows CBUSH elements to define preload.
 - JOINTG element enhanced to support newly added combination joints in OptiStruct.
 - JOINTG element enhanced to grounded Joint input.
 - MATFAT bulk card enhanced to include SNTBL continuation line for xy format inputs.
 - Mechanism browser enhanced to include Set as an input in addition to component input.
 - Multiple input selection for combined loads, for example: LOADADD, SPCADD, PTADD, and so on.
 - PCONT bulk card enhanced to input Main/Secondary surface for Auto contact in OptiStruct Explicit analysis.
 - SUPORT1 bulk card enhanced to input grid set.
 - Free format (comma separated) export for individual include file export.
 - MODCHG bulk card enhanced to input TIE contacts.
 - Non-Linear transient analysis type enhanced to input CNTSTB, MOTNJG and LOADJG subcase selection inputs.
 - PCONT bulk card enhanced to reference CLRNC bulk card.
 - LOADJG subcase selection input for Linear static analysis.
 - 3D visualization of taper beams
- Limited to standard sections
Figure 4.
 - Beam → Surfaces
- Create properties or nodal thickness on shell mesh created.
Figure 5. - Support for shell beamsections.
Figure 6.
 - Section Property tool for Elastic and Shells
- Section property now uses Elastic section config instead of Generic sections.
 - The tool can also generates shell beamsection with auto welds.
Resolved Issues
- Bead fraction response type selection as design constraint.
 - Cannot change local coordinate system for pattern repetition in DTPL card.
 - FE import reader crash caused by formatting of $HMNAME.
 - Move TIE bulk card from Explicit analysis to Contact folder in Solver Browser.
 - Application error while editing elements.
 - Incorrect ply thickness update in Matrix Browser for PCOMPG.
 - MAT9OR card name is now consistent with OptiStruct documentation.
 - Incorrect import of CBEAM elements.
