poIQueryCtrl GetDataSourceFieldDescriptionList
Gets a list of descriptions for the data fields for the specified data source.
poIQueryControl_handle GetDataSourceFieldDescriptionList source
HyperView Tcl Query
This command retrieves a list of field descriptions for the specified data source.
- source
 - The data source for which field description list is to be retrieved.
hwi OpenStack
variable t [expr rand()];
hwi GetActiveClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetQueryCtrlHandle myQueryName
myQueryName GetDataSourceFieldDescriptionList node
hwi CloseStack
Returns HW_InvalidHandle if the handle used to invoke the method is no longer valid.
