poIQueryCtrl GetDataSourceProperty
Gets the value of the specified property for a given source.
poIQueryControl_handle GetDataSourceProperty source property
HyperView Tcl Query
- source
 - The source for which the property is sought.
 - property
 - The property of which the value is sought.
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName GetDataSourceProperty node cornersErrors
Returns the data source property, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
