poIQueryCtrl SetQuery
Sets the query string.
poIQueryControl_handle SetQuery query
HyperView Tcl Modify
- query
 - The query string to be set.
Query Type Query Options Node Based node.id node.pool
node.rsys
node.asys
node.coords
component.id
component.pool
component.name
component.color
misc.load
misc.sim
misc.model
Element Based element.id element.pool
element.config
element.connectivity
element.normal
element.centroid
component.id
component.pool
component.name
component.color
misc.load
misc.sim
misc.model
Part Based component.id component.pool
component.name
component.color
misc.load
misc.sim
misc.model
System Based system.id system.pool
system.type
system.origin
system.x-axis
system.y-axis
system.z-axis
Result Based contour.value result.complex_value_M/P
result.complex_value_R/I
result.value
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName SetQuery "node.id result.value"Error
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
