The Trans Stiffness and Rot Stiffness tabs allow you to define the stiffness
        properties of a compliant joint or a bushing. Stiffness can be linear or
        non-linear.
                In the Trans Stiffness tab, complete the following steps:
                        For the Kx, Ky, Kz Linear field, enter the
                            translational stiffness coefficient in the local x, y, z
                            direction.
                        For the Kx, Ky, Kz Curve field, enter the force
                            transmitted through the bushing, expressed in the form of a force vs.
                            displacement curve that is a function of a set of independent
                            variables.
                                - Select an Interpolation method and enter a variable value.
                                - Resolve the curve by clicking Curve and
                                    selecting the curve to resolve.
                        For the Kx, Ky, Kz Spline3D field, complete the
                            steps below:
                                - Select an Interpolation method and enter an expression for
                                    Independent Variable X and Z.
                                - Resolve the 3D spline by clicking 3D
                                        Spline and selecting the entity to resolve.
                        For the Kx, Ky, Kz Expression field, enter the
                            force transmitted through the bushing, in the form of a function
                            expression.
                Click on the Rot Stiffness tab and complete the following steps:
                        For the Ktx, Kty, Ktz Linear field, enter the
                            rotational stiffness coefficient in the local x, y, z direction.
                        For the Ktx, Kty, Ktz Curve field, enter the
                            torque transmitted through the bushing, expressed in the form of a
                            torque vs. displacement curve that is a function of a set of independent
                            variables.
                        For the Ktx, Kty, Ktz Spline3D field, complete
                            the steps below:
                        For the Ktx, Kty, Ktz Expression field, enter
                            the torque transmitted through the bushing, in the form of a function
                            expression.
The Trans Damping and Rot Damping tabs allows you to define the damping
                properties of a compliant joint or bushing. Damping can be linear or non-linear.
                In the Trans Damping tab, complete the following steps:
                        For the Cx, Cy, Cz Linear field, enter the
                            translational damping coefficient in the local x, y, z direction.
                        For the Cx, Cy, Cz Curve field, enter the force
                            variables.
                        For the Cx, Cy, Cz Spline3D field, complete the
                            steps below:
                        For the Cx, Cy, Cz Expression field, enter the
                            expression.
                Click on the Rot Damping tab and complete the following steps:
                        For the Ctx, Cty, Ctz Linear field, enter the
                            rotational damping coefficient in the local x, y, z direction.
                        For the Ctx, Cty, Ctz Curve field, enter the
                            variables.
                        For the Ctx, Cty, Ctz Spline3D field, complete
                            the steps below:
                        For the Ctx, Cty, Ctz Expression field, enter
                            expression.
                Click the Preload tab.
                        For the Fx, Fy, Fz  field, enter the initial translational preloads in
                            the local x, y, z directions.
                        For the Tx, Ty, Tz  field, enter the initial torque preloads in the
