Fixed
                                 A fixed joint is a zero degree-of-freedom constraint. It applies a rigid connection         between the connecting bodies,
                                    meaning bodies connected by a fixed joint are forced to move         together. Fixed joints can be used to simulate connections
                                    where relative displacements are         idealized to zero, such as bolted connections, welded connections, and bodies that
                                    are fixed         in motion and orientation with respect to another body.
