An inline joint is a four degree-of-freedom primitive constraint. The constraint is
        imposed such that the origin of a reference marker on one body (Body 2) translates along the
        Z axis of a reference marker on the other body (Body 1) connected by the joint. Three
        rotations are free along with one translation along the Z marker defining the joint
        orientation. Joint primitives like inline joints may not have a physical existence. They can
        be used to impose unique constraints where using a regular joint would not be possible.
                If the Joints panel is not currently displayed, select the desired joint by
                    clicking on it in the Project Browser or in the modeling window.
The Joints panel is automatically displayed.
                From the Connectivity tab, click Body
                        1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
                    selected).
                    Note: If the selected joint is a pair entity, first distinguish between the
                            Left and Right tabs in the
                        panel, and then edit the properties. When defining a pair joint, use pair
                        entities for Body, Origin, etc.
                Similarly, click Body 2 and
                    select the desired body from the modeling window (or use
                    the Model Tree).
                Click the Point
                    collector (under Origin) and select a point from the modeling window, or double click the
                        Point collector to open the Model Tree (from which the desired point can be selected).
                Specify the axis that will define the constraint of the joint.
                    - Select Axis from the drop-down menu, specify
                        whether to use a vector or a point to define the direction, and make your
                        selection in the modeling window or the Model Tree.
Note: If the alignment axis for the joint is
                            along any of the global axes, then the global x, y,or z axis can be
                            selected by clicking on the desired axis in the modeling window (or by browsing through the Model Tree).
                    - Select Origin 2 from the drop-down menu, click
                            Point, and make your selection in the modeling window or the Model Tree.
Note: Selecting Origin 2 will define the axis along with the origin.
        If editing a compliant joint, see Edit Compliant Joints or Bushings. To edit user-defined
            properties, see Edit User-Defined Joints.
