A perpendicular axes joint is a five degree-of-freedom primitive constraint. The
        constraint is imposed such that the Z axis of a reference marker on one body (Body 2)
        remains perpendicular to the Z axis of a reference marker on the other body (Body 1)
        connected by the joint. All three translations are free along with two rotations about the Z
        axis of markers on both of the bodies defining the joint orientation. Joint primitives like
        perpendicular axes joints may not have a physical existence. These types of joints can be
        used to impose unique constraints where using a regular joint would not be possible.
        The perpendicular axes joint needs two axes (Axis 1 and Axis 2) that are mutually
            perpendicular and each belonging to Body 1 and Body 2 respectively.
                If the Joints panel is not currently displayed, select the desired joint by
                    clicking on it in the Project Browser or in the modeling window.
The Joints panel is automatically displayed.
                From the Connectivity tab, click Body
                        1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
                    selected).
                    Note: If the selected joint is a pair entity, first distinguish between the
                            Left and Right tabs in the
                        panel, and then edit the properties. When defining a pair joint, use pair
                        entities for Body, Origin, etc.
                Similarly, click Body 2 and
                    select the desired body from the modeling window (or use
                    the Model Tree).
                Click the Point
                    collector (under Origin) and select a point from the modeling window, or double click the
                        Point collector to open the Model Tree (from which the desired point can be selected).
                Define Axis 1.
                    - Point - Select a point that lies on the desired
                        alignment axis for the joint.
                    - Vector - Global axes can be used for vectors by
                        clicking on the desired axis (x, y, or z) in the modeling window or by browsing through the Model Tree.
                Define Axis 2 using the same steps.
        If editing a compliant joint, see Edit Compliant Joints or Bushings. To edit user-defined
            properties, see Edit User-Defined Joints.
