A screw joint is a five degree-of-freedom kinematic pair used in mechanisms. Screw
        joints imposes a relation between the rotation of one body (Body 1) about an axis to the
        translation of the other body (Body 2) along an axis. The pitch of the joint completes this
        relation. One full rotation of Body 1 translates Body 2 by a distance equal to the pitch.
        Screw joints are commonly used in applications such as bolt and nut constraints and rack and
        pinion steering.
                If the Joints panel is not currently displayed, select the desired joint by
                    clicking on it in the Project Browser or in the modeling window.
The Joints panel is automatically displayed.
                From the Connectivity tab, click Body
                        1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
                    selected).
                    Note: If the selected joint is a pair entity, first distinguish between the
                            Left and Right tabs in the
                        panel, and then edit the properties. When defining a pair joint, use pair
                        entities for Body, Origin, etc.
                Similarly, click Body 2 and
                    select the desired body from the modeling window (or use
                    the Model Tree).
                Click the Point
                    collector (under Origin) and select a point from the modeling window, or double click the
                        Point collector to open the Model Tree (from which the desired point can be selected).
                Specify the alignment axis for the joint.
                    - Point - Select a point that lies on the desired
                    - Vector - If the alignment axis for the joint is
                        along any of the global axes, then the global x, y,or z axis can be selected
                        by clicking on the desired axis in the modeling window or by browsing through the Model Tree.
                Click the Properties tab and enter a value for Pitch.
        If editing a compliant joint, see Edit Compliant Joints or Bushings. To edit user-defined
            properties, see Edit User-Defined Joints.
