A constant velocity joint is a two degree-of-freedom constraint. It constrains the
        rotation of a body (Body 1) about a specified axis to be equal to the rotation of the other
        body (Body 2) connected by the joint. The axis of rotation is the Z axes of the markers
        defined on the connecting user-defined bodies. Constant velocity joints are widely used in
        drive shafts of vehicles with independent suspension.
                If the Joints panel is not currently displayed, select the desired joint by
                    clicking on it in the Project Browser or in the modeling window.
The Joints panel is automatically displayed.
                From the Connectivity tab, click Body
                        1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
                    selected).
                    Note: If the selected joint is a pair entity, first distinguish between the
                            Left and Right tabs in the
                        panel, and then edit the properties. When defining a pair joint, use pair
                        entities for Body, Origin, etc.
                Similarly, click Body 2 and
                    select the desired body from the modeling window (or use
                    the Model Tree).
                Click the Point
                    collector (under Origin) and select a point from the modeling window, or double click the
                        Point collector to open the Model Tree (from which the desired point can be selected).
                Specify each axis.
                    - Point - Select a point which lies along the shaft
                        axis in the modeling window or double-click the
                            Point button and choose a point from the Model Tree.
                    - Vector - Select a vector which defines the
                        direction of orientation of the shaft axis. If the alignment axis for the
                        joint is along any of the global axes, then the global x, y, or z axis can
                        be selected by clicking on the desired axis in the modeling window (or by double-clicking the
                            Vector button and browsing through the Model Tree).
        If editing a compliant joint, see Edit Compliant Joints or Bushings. To edit user-defined
            properties, see Edit User-Defined Joints.
