Auxiliary Posts
- Posts can be added or deleted using the Add or Delete buttons respectively.
 - Attachments for each Auxiliary Post consist of Body, Apply to Point and Mount
            Point.Note: The direction of the Displacement/Force application is from Mount Point to Apply to Point.
The post is connected using Ball Joints at both ends, to the Body on which the Force/Displacement is applied and to the Body on which the post is mounted (GroundBody).
 - Signal Type - There are three signal types that can be used for the input to an
          Auxiliary Post:
- Displacement
 - Force/Moment
 - Acceleration: Acceleration is first converted to displacement, following which the displacement is applied.
Figure 1. Auxiliary Post Functions and Options
