Troubleshooting Tips
- The road property file should be compatible with the tire property file that is used in the vehicle.
 - The units in the path profile will be used when the independent variable in the velocity profile is set to Distance.
 - The MotionView curve entity used to define the velocity profile should have the same units as specified in the Units field.
 - The road centerline option will work (to generate the ddf), only if the road property file provided can be used by the Roads tools functionality.
