A stabar, also known as anti-roll bar, is a member that is used in automobile
        suspensions to increase roll stiffness. This helps reduce the body roll of a vehicle during
        cornering or when the vehicle traverses on road undulations.
        An NLFE Stabar system is a
MotionView system definition that can be used to represent a
            stabar as a non-linear finite element body assembled with accessories like drop links
            and attachment joints. A Stabar needs the following entities to be present in the
                model:
                - A vehicle body on which the stabar is mounted.
                - Suspension components like control arms/knuckles, etc. to which the stabar end
                    drop-links are attached.
                - Optionally, a pair of points for the drop-link attachments to the suspension
                    components mentioned above.
                From the Subsystems toolbar, click the NLFE Stabar
                        Subsystem toolbar icon
                The Add an NLFEStabar Subsystem dialog is
                    displayed.
                Click the System collector and decide which system the
                    stabar needs to be created in.
                Specify a variable name and label for the stabar.
By default, variable names of entities in MotionView follow a certain convention. For example, all NLFE stabar entities have a
                    variable name starting with nlfesb_. This is the recommended
                    convention to follow when building models in MotionView since it has many advantages in model editing
                    and model manipulation.
                Double-click the MaterialProperty collector and select a
                    material to define the stabar, or accept Steel as the default.
                Click the Body collector and select the vehicle body on
                    which the stabar is mounted from the modeling window, or
                    double-click the collector to display the Model Tree
                    (from which the desired body can be selected).
                In the same manner, select the attaching points and bodies on either side for
                    the drop link.
                    Note: Select Point 1 and Point 2
                        if available in the model. If not, activate the Use global point
                            coordinates check box and enter in the coordinates where
                        points for the attachments are to be created.
                Enter Outer and Inner diameter values for the stabar tube.
                Click on the Profile Points tab to define the profile of
                    the stabar.
                Manually enter values for the profile points in the table of coordinates or
                    import values with a .csv file.
                    Tip: To change the number of points in the table, enter a value in
                        the Total number of points text box.
                Click the Marker collector and select a reference marker
                    in which the profile points are defined.
The default is the global frame.
                Among the profile points defined, select two points as locations to attach the
                    stabar to the mount body (frame) using the check box in the column at the
                    right.
                Click OK.
The stabar system that is created has the following architecture:
                                    | Entity |
                                    Description |
                                    | Body |
                                    An NLFE body entity for the stabar is created using the
                                        profile points. |
                                    | DataSet |
                                    A dataset where editable values are populated. After the
                                        creation of the stabar, you can change the outer diameter
                                        and inner diameter from this dataset. |
                                    | Points |
                                    The points that define the stabar profile are created.
                                    | Graphics |
                                    Graphics are created for the joints for
                                        visualization. |
                                    | Joints |
                                    Compliant joints are created to define connections
                                        between Stabar – Frame – Drop link – Suspension
                                        components. |
                                    | Outputs |
                                    Output requests are created to measure stabar and drop
                                        link forces. |
            Tip:
                    - Activate Show additional parameters to specify
                        variable names and labels for the points that are to be created.
                    - If at any point you want to return to default settings, simply click
                            Reset to Defaults.
