ValueAtTime
Model ElementValueAtTime computes the value of a signal, f(Q,U,Ud)
Class Name
ValueAtTime
where:
Attribute Summary
| Name | Property | Modifiable by Command? | Designable |
| label | Str () | ||
| atTime | Double () | ||
| measuredValue | Function () | Yes | |
| delta | Double (1.0E-3) | ||
| scale | Double (1) |
Usage
ValueAtTime (atTime=double, measuredValue=expressionString, delta=double,
optional_attributes)
Attributes
- atTime
- Double
- measuredValue
- expressionString
- label
- String
- delta
- Double
- scale
- Double
Example:
# Compute the ROLL angle of a marker wrt. ground @ time T=1.2 in degrees
roll = "RTOD*AZ({I})".format(I=m.coupler.cm2.id)
roll12 = ValueAtTime (
label = "Roll at T=1.2",
measuredValue = roll,
delta = 0.02,
atTime = 1.2,
