Linear Transient Analysis
Calculates the response of a structure to time-dependent loads. Typical applications are structures subject to earthquakes, wind, explosions, or a vehicle going through a pothole.
The loads are time-dependent forces and displacements. Initial conditions define the initial displacement and initial velocities in grid points.
The results of a transient response analysis are displacements, velocities, accelerations, forces, stresses, and strains. The responses are usually time-dependent.
The transient response analysis computes the structural responses solving the following equation of motion with initial conditions in matrix form.(1) M u ¨ + C u ˙ + K u = f ( t ) (2) u t = 0 = u 0 (3) u ˙ t = 0 = v 0
The matrix K is the global stiffness matrix, the matrix M the mass matrix, and the matrix C is the damping matrix formed by the damping elements. The initial conditions are part of the problem formulation and are applicable for the direct transient response only. The equation of motion is integrated over time using the Newmark beta method. A time step and an end time need to be defined.
Direct and modal transient response analysis methods are implemented as follows.
Linear Direct Transient Response
The equation of motion is solved directly using the Newmark Beta method.
The use of complex coefficients for damping is not allowed in transient response analysis. Therefore, structural damping is included using equivalent viscous damping.
The damping matrix C is composed of several contributions as:(4) C = C 1 + G ω 3 K + 1 ω 4 C G E
Where,
C 1
Matrix of the viscous damper elements, plus the external damping matrices input through the DMIG Bulk Data Entry.
G
Overall structural damping (PARAM, G).
ω 3
Frequency of interest for the conversion of the overall structural damping into equivalent viscous damping (PARAM, W3).
ω 4
Frequency of interest for the conversion of the element structural damping into equivalent viscous damping (PARAM, W4).
C G E
Contribution from structural element damping coefficients G E .
There are two approaches to solving the energy equation in direct transient response. This time integration scheme is controlled via the TMTD field on the TSTEP Bulk Data Entry.
  1. Traditional Method (Default – TMTD is blank)
  2. Newmark-Beta Method (TMTD = 1)
The Newmark-Beta time integration scheme is available for linear direct transient analysis as an alternative to the traditional method. This method is activated by setting the TMTD field to 1 on the TSTEP Bulk Data Entry for Linear Direct Transient Analysis.(5) v n+1 = v n +( 1−γ )h a n +γh a n+1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWH2bWaaSbaaSqaaiaad6gacqGHRa WkcaaIXaaabeaakiabg2da9iaahAhadaWgaaWcbaGaamOBaaqabaGc cqGHRaWkdaqadaqaaiaaigdacqGHsislcqaHZoWzaiaawIcacaGLPa aacaWGObGaaCyyamaaBaaaleaacaWGUbaabeaakiabgUcaRiabeo7a NjaadIgacaWHHbWaaSbaaSqaaiaad6gacqGHRaWkcaaIXaaabeaaaa a@4884@ (6) u n+1 = u n +h v n + h 2 ( 1 2 −β ) a n + h 2 β a n+1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWH1bWaaSbaaSqaaiaad6gacqGHRa WkcaaIXaaabeaakiabg2da9iaahwhadaWgaaWcbaGaamOBaaqabaGc cqGHRaWkcaWGObGaaCODamaaBaaaleaacaWGUbaabeaakiabgUcaRi aadIgadaahaaWcbeqaaiaaikdaaaGcdaqadaqaamaalaaabaGaaGym aaqaaiaaikdaaaGaeyOeI0IaeqOSdigacaGLOaGaayzkaaGaaCyyam aaBaaaleaacaWGUbaabeaakiabgUcaRiaadIgadaahaaWcbeqaaiaa ikdaaaGccqaHYoGycaWHHbWaaSbaaSqaaiaad6gacqGHRaWkcaaIXa aabeaaaaa@4F1F@ (7) M a n+1 +B v n+1 +K u n+1 = f n+1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCytaiaahg gadaWgaaWcbaGaamOBaiabgUcaRiaaigdaaeqaaOGaey4kaSIaaCOq aiaahAhadaWgaaWcbaGaamOBaiabgUcaRiaaigdaaeqaaOGaey4kaS IaaC4saiaahwhadaWgaaWcbaGaamOBaiabgUcaRiaaigdaaeqaaOGa eyypa0JaaCOzamaaBaaaleaacaWGUbGaey4kaSIaaGymaaqabaaaaa@4A1A@
Where,
M MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWHnbaaaa@3291@ , C MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWHnbaaaa@3291@ , and K MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWHnbaaaa@3291@
Mass, viscous damping, and stiffness matrix, respectively.
f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWHnbaaaa@3291@
Total force.
β and γ
Can be modified via the TC2 and TC3 fields of the TSTEP Bulk Data Entry.
h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGObaaaa@32A8@
Timestep.
Automatic Time Stepping
The Linear Transient solution provides automatic time stepping based on Local Truncation Error (LTE) for the Newmark-Beta time integration scheme. This can be controlled using the MREF field of the TSTEP Bulk Data Entry.
From Taylor’s expansion, the LTE of displacement u MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWH1baaaa@32B9@ from time t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDaaaa@36F0@ to t + h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDaiabgU caRiaadIgaaaa@38BF@ is:(8) e = 1 6 h 3 u ⃛ ( τ ) t < τ < t + h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakqaabeqaaiaadwgacqGH9aqpdaWcaaqaai aaigdaaeaacaaI2aaaaiaadIgadaahaaWcbeqaaiaaiodaaaGcceWH 1bGbaqaadaqadaqaaiabes8a0bGaayjkaiaawMcaaaqaaiaadshacq GH8aapcqaHepaDcqGH8aapcaWG0bGaey4kaSIaamiAaaaaaa@4303@
Using acceleration, e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGLbaaaa@32A5@ can be approximated as:(9) e = 1 6 h 2 | Δ a | MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGLbGaeyypa0ZaaSaaaeaacaaIXa aabaGaaGOnaaaacaWGObWaaWbaaSqabeaacaaIYaaaaOWaaqWaaeaa cqqHuoarcaWHHbaacaGLhWUaayjcSdaaaa@3C88@
For coupled Multiple DOF system, the above absolute value is replaced by certain norm of Δ a MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacqqHuoarcaWHHbaaaa@340A@ . Here the mass-weighted norm is used, so that:(10) e = 1 6 h 2 ( Δ a T M Δ a ) 1 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGLbGaeyypa0ZaaSaaaeaacaaIXa aabaGaaGOnaaaacaWGObWaaWbaaSqabeaacaaIYaaaaOWaaeWaaeaa cqqHuoarcaWHHbWaaWbaaSqabeaacaWGubaaaOGaaCytaiabfs5aej aahggaaiaawIcacaGLPaaadaahaaWcbeqaamaaliaabaGaaGymaaqa aiaaikdaaaaaaaaa@40DA@
Error estimation in the previous equation requires normalization, as it depends on certain reference displacement, for example, initial displacement, as well as cut-off frequency. The normalized error estimation is:(11) e ˜ = e K Ω ‖ u R ‖ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaaceWGLbGbaGaacqGH9aqpdaWcaaqaai aadwgaaeaacaWGlbWaaSbaaSqaaiabfM6axbqabaGcdaqbdaqaaiaa hwhadaWgaaWcbaGaamOuaaqabaaakiaawMa7caGLkWoaaaaaaa@3C7A@
Here, K Ω MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGlbWaaSbaaSqaaiabfM6axbqaba aaaa@3445@ is the time-averaged Local Truncation Error (LTE) measure of a linear undamped single DOF oscillator with unit initial displacement and oscillating at approximately 10 cycles per second or with cut-off frequency Ω = ω h = 0.6 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuyQdCLaey ypa0JaeqyYdCNaamiAaiabg2da9iaaicdacaGGUaGaaGOnaaaa@3E77@ ( ω is the natural frequency of the single DOF system). (12) K Ω = Ω 3 ( 1 + 0.25 Ω 2 ) 0.5 3 π ( 1 + β Ω 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacqqHPoWvaeqaaOGaeyypa0ZaaSaaaeaacqqHPoWvdaahaaWc beqaaiaaiodaaaGcdaqadaqaaiaaigdacqGHRaWkcaaIWaGaaiOlai aaikdacaaI1aGaeuyQdC1aaWbaaSqabeaacaaIYaaaaaGccaGLOaGa ayzkaaWaaWbaaSqabeaacaaIWaGaaiOlaiaaiwdaaaaakeaacaaIZa GaeqiWda3aaeWaaeaacaaIXaGaey4kaSIaeqOSdiMaeuyQdC1aaWba aSqabeaacaaIYaaaaaGccaGLOaGaayzkaaaaaaaa@50D4@
Where, ‖ u R ‖ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqbdaqaaiaahwhadaWgaaWcbaGaam OuaaqabaaakiaawMa7caGLkWoaaaa@36ED@ is the maximum value of the displacement norm over all the previous time steps.
(13) ‖ u R ‖= max 1≤j≤n ( ‖ u j ‖ ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaadaqbdaqaaiaahwhadaWgaaWcbaGaam OuaaqabaaakiaawMa7caGLkWoacqGH9aqpdaWfqaqaaiGac2gacaGG HbGaaiiEaaWcbaGaaGymaiabgsMiJkaadQgacqGHKjYOcaWGUbaabe aakmaabmaabaWaauWaaeaacaWH1bWaaSbaaSqaaiaadQgaaeqaaaGc caGLjWUaayPcSdaacaGLOaGaayzkaaaaaa@47E4@
Where, u j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWH1bWaaSbaaSqaaiaadQgaaeqaaa aa@33D4@ is the displacement at time step j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ .
The norm is defined as:(14) ‖ u j ‖= ( u j ) T M( u j ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaauWaaeaaca WH1bWaaSbaaSqaaiaadQgaaeqaaaGccaGLjWUaayPcSdGaeyypa0Za aOaaaeaadaqadaqaaiaahwhadaWgaaWcbaGaamOAaaqabaaakiaawI cacaGLPaaadaahaaWcbeqaaiaadsfaaaGccaWHnbWaaeWaaeaacaWH 1bWaaSbaaSqaaiaadQgaaeqaaaGccaGLOaGaayzkaaaaleqaaaaa@45A0@
The time steps are automatically adjusted based on the following conditions (TOL is the user-defined tolerance set on the TSTEP Bulk Data Entry):
  • If e ˜ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabmyzayaaia aaaa@36EF@ > TOL: Reject current step, cutback to half the current time step, and redo the current step.
  • If TOL > e ˜ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabmyzayaaia aaaa@36EF@ > 0.5 * TOL: Accept current step, cutback the next time step to half the current time step.
  • If 0.5 * TOL > e ˜ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabmyzayaaia aaaa@36EF@ > 1/16 * TOL: No changes.
  • If 1/16 * TOL > e ˜ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabmyzayaaia aaaa@36EF@ : The next time step is enlarged to 1.25 times the current time step.
The MREF continuation line on TSTEP entry can be used to control automatic time stepping, so that the time step h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ is adjusted according to the LTE of the current step. As shown above, when error is "large" when compared to the tolerance (TOL), h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ will be reduced by half and the current step is re-calculated. The maximum number of such operations within each step is controlled by the TN1 field. On the other hand, when h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ is "small" compared to the tolerance (TOL), h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ is requested to be increased, but only after TN2 contiguous steps with such a request, will h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ be actually increased.
Run Linear Transient Analysis
The Loads and Boundary Conditions are defined in the Bulk Data Entry section of the input deck. They need to be referenced in the Subcase Information section using an SPC statement and a DLOAD statement in a SUBCASE. Similar to mechanical loads, temperature loads (TEMP/TEMPD/TEMPADD) can be applied to Linear Transient Analysis via TLOAD1/TLOAD2 Bulk Data Entries referenced on a DLOAD Subcase Information Entry.
Inertia relief is not supported for Linear Transient Analysis. OptiStruct will error out if this is attempted.
Only one transient subcase can be defined. Initial conditions need to be referenced through the IC Subcase statement. The analysis time step and termination time need to be defined through a TSTEP(TIME) subcase reference. The corresponding time integration scheme can be selected via the TMTD field on the TSTEP entry. Automated time-stepping is controlled via the MREF field on TSTEP entry. MREF = 0 turns off automatic time-stepping and MREF=1 activates automated time-stepping.
In addition to the various damping elements and material damping, uniform structural damping G can be applied using PARAM, G.
Linear Modal Transient Response
In the modal method, a normal modes analysis to obtain the eigenvalues λ i = ω i 2 and the corresponding eigenvectors A = A i of the system is performed first.
The state vector u can be expressed as a scalar product of the eigenvectors A and the modal responses v .(15) u = A v
The equation of motion without damping is then transformed into modal coordinates using the eigenvectors:(16) A T M A v ¨ + A T K A v = A T f
The modal mass matrix A T M A and the modal stiffness matrix A T K A are diagonal. This way the system equation is reduced to a set of uncoupled equations for the components of v that can be solved easily.
The inclusion of damping yields:(17) A T M A v ¨ + A T C A v ˙ + A T K A v = A T f
Here, the matrices A T C A are generally non-diagonal. Then coupled problem is similar to the system solved in the direct method, but of a much lesser degree of freedom. The solution of the reduced equation of motion is performed using the Newmark method.
The decoupling of the equations can be maintained, if the damping is applied to each mode separately. This is done through the damping tables, that can be defined using these methods:
  • TABDMP1 lists damping values g i versus natural frequency f i .
  • TABDMP2 lists damping values g i versus range of mode indices.
The decoupled equation is:(18) m i v ¨ i ( t ) + c i v ˙ i ( t ) + k i v i ( t ) = f i ( t )
or(19) v ¨ i ( t ) + 2 ζ i ω i v ˙ i ( t ) + ω i 2 v i ( t ) = 1 m i f i ( t )
Where,
ζ i = c i / ( 2 m i ω i )
Modal damping ratio
ω i 2
Modal eigenvalue
Three types of modal damping values g i ( f i ) can be defined:
G
Structural damping
C R I T
Critical damping
Q
Quality factor
They are related through the following three equations at resonance:(20) G = ζ i = c i c c r = g i 2 (21) C R I T = c c r = 2 m i ω i (22) Q = Q i = 1 2 ζ i = 1 g i
Residual Vector Generation (Increases Accuracy)
The accuracy of the modal method can be vastly improved by adding the displacement vectors of a static analysis based on the dynamic loading to the matrix of eigenvectors X . These vectors are frequently referred to as residual vectors, the method as modal acceleration.
There are two ways this is implemented.
  • The unit load method generates residual vectors based on static loads, which are unit vectors at the dynamic load degrees of freedom. That is, the static loads for the residual vector generation are unit vectors at the degrees of freedom, where the dynamic load is applied. The number of residual vectors is equal to the number of loaded degrees of freedom.
  • The applied load method generates a maximum of two residual vectors which are the dynamic load vector at loading frequency of zero. If the real and the imaginary parts of the dynamic load are the same, or if one of them is zero, only one of them is used. This is the default method since it is generally more efficient.
In the case of excited displacements, the residual vectors are obtained by solving static load cases with unit displacements at the same degrees of freedom as the dynamic excited displacement degrees of freedom.
Run Linear Modal Transient Analysis
Loads and Boundary Conditions are defined in the Bulk Data Entry section of the input deck. They need to be referenced in the Subcase Information Entry section using an SPC statement and a DLOAD statement in a SUBCASE. Similar to mechanical loads, temperature loads (TEMP/TEMPD/TEMPADD) can be applied to Linear Transient Analysis via TLOAD1/TLOAD2 Bulk Data Entries referenced on a DLOAD Subcase Information Entry.
Residual vectors can be activated using the Subcase statement RESVEC with the options APPLOD or UNITLOD. They are computed by default. Residual vectors are always generated if enforced displacements, velocities or accelerations are defined. Residual vectors are also calculated for viscous damping DOF. These are created by default and can be turned off with the RESVEC option NODAMP. In addition, if there is USET U6 data, residual vectors will be calculated if the AMSES or AMLS eigensolver is used. USET U6 residual vectors will not be calculated if the Lanczos eigensolver is used.
When residual vectors are included, Inertia Relief can be applied to unconstrained models. A SUPORT1 Subcase Information Entry references the boundary conditions that restrain the rigid body motions. These restraints can also be defined without subcase reference using the SUPORT Bulk Data Entry or automated using PARAM,INREL, -2.
Only one transient subcase can be defined. Initial conditions cannot be defined if the modal method is used. A METHOD statement is required for the modal method to control the normal modes analysis. The METHOD statement can refer to either EIGRL or EIGRA data.
The analysis time step and termination time need to be defined through a TSTEP(TIME) subcase reference. In order to save computational effort, previously saved eigenvectors can be retrieved using the EIGVRETRIEVE subcase statement.
In addition to the various damping elements and material damping, uniform structural damping G is applied using PARAM, G.
Modal damping can be applied using the SDAMPING reference of a damping table TABDMP1.
Output
The responses are usually time-dependent. The usual output entries like STRESS, STRAIN, DISPLACEMENT, etc. can be used to request corresponding output values. The NLLOAD I/O Options Entry can be used to request the output of nonlinear loads for each time step.
DISP(MODAL) can be used to output only the eigenvectors in Modal FRF/Transient response. DISP(MODAL,NODAL) can be used to output both the eigenvectors and the corresponding FRF/Transient response results.
PARAM, ENFMOTN, REL can be used to generate displacement, velocity and acceleration output relative to the specified enforced motion. In such cases, subsequently calculated outputs like stresses and forces are also generated relative to the specified enforced motion. PARAM, ENFMOTN, TOTAL/ABS can be used to generate the total output values including the specified enforced motion (TOTAL/ABS is the default).
Linear Transient Analysis by Fourier Transformation
With the Fourier transformation method, Frequency Response Analysis can be used for the Transient Analysis. The Fourier transformation method may be used to solve the transient response of structural models under periodic loads.
A typical application for this method is a vehicle on a bumpy road.
Time-dependent applied loads are transformed into the frequency domain and all frequency dependent matrix calculations are completed. The frequency response results are then transformed back into the time domain.
The following equation of motion with initial conditions in matrix form is solved:(23) M u ¨ + C u ¨ + K u = f ( t )
The matrix K is the stiffness matrix, the matrix M is the mass matrix, and the matrix C is the damping matrix formed by the damping elements. Initial conditions cannot be defined.
The load vector is transformed from the time domain into the frequency domain using:(24) f ( Ω ) = ∫ 0 T f ( t ) e − i Ω t d t
The response in given by:(25) u ( Ω ) = h ( Ω ) f ( Ω )
Where, h ( Ω ) is the frequency response due to unit load.
After the Frequency Response Analysis, the time-dependent response can be recovered using:(26) u ( t ) = 1 π ∫ 0 ∞ Real [ u ( Ω ) e i Ω t ] d Ω
For the results to be accurate, it is important to note that:
  1. The system has to be reasonably well damped. Too little damping may lead to incorrect results.
  2. The forcing function should be zero for some time interval to allow decay.
  3. The frequency interval should follow:(27) Δ Ω ≤ 1 T p u l s e + T d e c a y
The direct and modal methods are implemented. The Linear Transient Analysis using Fourier Transformation cannot be used in a model, which also contains a Modal Frequency Response Analysis subcase. OptiStruct will error out in such cases.
Input/Output
Direct Method
Direct frequency response analysis is applied (Frequency Response Analysis).
Loads and Boundary Conditions are defined in the Bulk Data Entry section of the input deck. They need to be referenced in the Subcase Information Entry section using an SPC and DLOAD statement in a SUBCASE.
Inertia relief is not implemented for direct frequency response. The solver will error out if it is attempted.
A frequency set must be referenced using a FREQUENCY statement. Initial conditions cannot be applied. The analysis time step and termination time need to be defined through a TSTEP(FOURIER) subcase reference.
Modal Method
Modal Frequency Response Analysis is applied (Frequency Response Analysis).
Transient response loads and boundary conditions are defined in the Bulk Data Entry section of the input deck. They need to be referenced in the Subcase Information Entry section using an SPC and DLOAD statement in a SUBCASE.
When residual vectors are included, Inertia Relief can be applied to unconstrained models. A SUPORT1 Subcase Information Entry references the boundary conditions that restrain the rigid body motions. These restraints can also be defined without subcase reference using the SUPORT Bulk Data Entry or automated using PARAM, INREL, -2.
A frequency set must be referenced using a FREQUENCY statement. Initial conditions cannot be defined. A METHOD statement is required for the modal method to control the normal modes analysis. The analysis time step and termination time need to be defined through a TSTEP(FOURIER) Subcase reference. In order to save computational effort, previously saved eigenvectors can be retrieved using the EIGVRETRIEVE Subcase statement.
Modal damping can be applied using the SDAMPING reference of a damping table TABDMP1. The parameter PARAM, KDAMP is to define the method of applying the damping table.
Output
The results for Linear Transient Analysis via Fourier transformation are displacements, velocities, and accelerations. Time-based results are output by default (TIME option) and, for supported output entries, frequency-based results can be requested using the FREQ option in the corresponding I/O Options Entry (for example, DISPLACEMENT(FREQ)).
