OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Elements are a fundamental part of any finite element analysis, since they completely represent (to an acceptable
approximation), the geometry and variation in displacement based on the deformation of the structure.
The different material types provided by OptiStruct are: isotropic, orthotropic, and anisotropic materials. The material property definition cards are used to
define the properties for each of the materials used in a structural model.
High Performance Computing leverages computing power, in standalone or cluster form, with highly efficient software,
message passing interfaces, memory handling capabilities to allow solutions to improve scalability and minimize run
times.
Contact is an integral aspect of the analysis and optimization techniques that is utilized to understand, model, predict,
and optimize the behavior of physical structures and processes.
Heat transfer describes the physical phenomena of the flow of thermal energy from regions of high temperature to a
region of lower temperature, until thermal equilibrium is reached.
Temperature history is available after a Linear Transient Heat Transfer Analysis or Nonlinear Transfer Heat Transfer
Analysis. One Step Transient Thermal Stress Analysis (OSTTS) is used to apply this temperature history (at multiple
output time steps) to a Structural Analysis.
OptiStruct and AcuSolve are fully-integrated to perform a Direct Coupled Fluid-Structure Interaction (DC-FSI) Analysis based on a
partitioned staggered approach.
Aeroelastic Analysis is the study of the deflection of flexible aircraft structures under aerodynamic loads, wherein
the deformation of aircraft structures in turn affect the airflow.
OptiStruct provides industry-leading capabilities and solutions for Powertrain applications. This section aims to highlight OptiStruct features for various applications in the Powertrain industry. Each section consists of a short introduction, followed
by the typical Objectives in the field for the corresponding analysis type.
This section provides an overview of the capabilities of OptiStruct for the electronics industry. Example problems pertaining to the electronics industry are covered and common solution
sequences (analysis techniques) are demonstrated.
OptiStruct generates output depending on various default settings and options. Additionally,
the output variables are available in a variety of output
formats, ranging from ASCII (for example, PCH) to binary files (for example,
H3D).
A semi-automated design interpretation software, facilitating the recovery of a modified geometry resulting from a
structural optimization, for further use in the design process and FEA reanalysis.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
The Thermal Analysis section provides an overview of the following
analyses.
Heat transfer describes the physical phenomena of the flow of thermal energy from regions of high temperature to a region of lower temperature, until thermal equilibrium is reached.
Temperature history is available after a Linear Transient Heat Transfer Analysis or Nonlinear Transfer Heat Transfer Analysis. One Step Transient Thermal Stress Analysis (OSTTS) is used to apply this temperature history (at multiple output time steps) to a Structural Analysis.
Contact-based Thermal Analysis
In OptiStruct, structural models involving contact are solved by using Small Displacement Nonlinear Analysis.
