Nodal Boundary Conditions
- Fixed and full slip boundary conditions
- Imposed velocities (imposed flux at inlet)
- Rigid links (temporary adds during restarts)
- Rigid bodies to model rigid structures and connections and also to compute drag and lift forces (fluid impulse on rigid body is stored in time history database)
- Fixed and full slip grid conditions
- Lagrangian conditions (grid and material velocity are equally set)
- ALE links to maintain regular distribution of nodes
- Imposed grid velocities (moving inlet and outlet)
Example:
If set Grilag=010 000, it means just fix grid in Y direction, material could move in Y direction.
If set Grilag=000 010, it means nodes are like Lagrangian in Y direction, gird and material are tied on these nodes in Y direction.
