View Binder Sinter Analysis Results
View, animate, and plot the results of a binder sintering analysis.
- To change the legend color for the result type, click the icon next to the results slider and select Legend Colors.
- To delete a run from the Analysis Explorer, right-click the run name to select Delete Run from the context menu.
Show Options
Determine what is made visible in the modeling window when viewing analysis results. You can show or hide the initial shape, loads and supports, deformation, and/or contours.
Option | Description | Note | |
Show/Hide Initial Shape | ![]() |
Show/hide the initial shape as a reference. | |
Show/Hide All Loads and Supports | ![]() |
Show/hide loads and supports. You can also show only the current loads and supports. | |
Show/Hide Deformed State | ![]() |
Show/hide the deformed shape as a reference. | |
Show/Hide Contours | ![]() |
Show/hide contours. | |
Options | ![]() |
Show/Hide Elements | ![]() ![]() |
Show/hide the element edges. | This icon appears under the view controls in the lower left of the modeling window, but only when the Analysis Explorer is active. |
Callouts
Create, show, hide, and list callouts for selected result types at points of interest on your model.
After running an analysis, click the Show Analysis Results on the Analyze icon. Options for callouts appear in the Callouts section of the Analysis Explorer.
Callout Icon | Description | Note |
Create, Show, and Hide Callouts![]() |
Click the ![]() |
After creating callouts, click the ![]() |
List Callouts![]() |
Display a list of all callouts in a table. Each callout is specific to the selected run. For structural analysis, it is also specific to the selected load case. | Click the ![]() |
Min/Max Callouts![]() |
Create a callout showing where the minimum/maximum value occurs for
the selected result type. Note: When factor of safety
is selected, the minimum value is shown.
Click the min/max callout in the modeling window to create a regular callout at the same location. |
Options![]() |
Dynamic Callouts: Make callouts dynamic, so they display the value of the currently selected result type. | If you enable the Compare Results feature in a callout, the callout becomes static. |
Plot Print3D Results
If you've previously run a 3D printing analysis, you can plot the results from the Analysis Explorer.
