An immersion quench zone is a rectangular box with coolant, and the extruded profile goes through this coolant. In
this process, it is completely immersed in the coolant.
The quench system database allows you to save created quench systems. You can retrieve the stored quench systems from
the database to reuse in future simulations.
goes through this coolant. In this process, it is completely immersed in the coolant.
From the Quenching ribbon, click the
Quench tool.
The secondary toolbar with quench zone types is displayed.
Click the Immersion icon.
Adjust the zone position over the profile using the move tool in
the micro dialog to move the box in X,Y, Z directions.
A rectangular quench zone will be created. Micro dialogs to edit the box
dimensions will be populated along width, length and height of the box.
Another micro dialog with immersion zone parameters will be populated to
edit the coolant temperature and zone start location.
