An immersion quench zone is a rectangular box with coolant, and the extruded profile goes through this coolant. In
this process, it is completely immersed in the coolant.
The quench system database allows you to save created quench systems. You can retrieve the stored quench systems from
the database to reuse in future simulations.
Review a dialog with a list of created quench zones.
In the Quench group, click the
icon.
A dialog with the list of quench zones created is
populated. You can enable or disable any side of the listed quench zones from the zone
table.
Note: Toggling cooling sides means only selected sides will be exported into
the quench data file and involved in simulation. This allows the user the option to
play with different sets of cooling combinations without deleting and adding the
cooling system repeatedly.
Note: Changes will be applied only in the current
session. They will not be saved to the database.
