Compare Renderings
Compare two renderings so that you can edit one image in reference to the other. The renderings must be of the same size and cannot have Relight enabled.
                On the Rendering tab, click the Darkroom icon.
                Select two images for comparison:
                Important: The renderings must be of the same size and cannot have Relight enabled. The size is indicated at the top left corner, while Relight is indicated by a "R" in the top right corner of the image.
- Hold down Ctrl (Win) or Command (Mac) while clicking the images.
 - Click the Compare Images
 icon.
 - Optional: To see more of the Reference of Edit side, hold down Shift while dragging the image with the right mouse button.
                To view the display settings for the Reference image,
                    click the Show Information
 icon.
             - Modify the Display Settings for the Edit image as desired.
                To export the Edit image without saving the display
                    settings, click the Save as
 icon.
             - To save the display settings, click the Save button.
