All machines
The computation time has increased a lot for transient thermal computations
The computation time needed for the test Characterization/Thermal/Transient is much higher than in the previous version (14 minutes instead of 2 minutes for instance). There is the same problem with the test Performance mapping - Efficiency map while computing user working point(s) analysis with thermal solving.
This issue will be fixed in the next version (ref.: FXM-15653 and FXM-15654).
Full geometry is provided although periodicity would be possible
While exporting a project to Flux 2d or Skew, the periodicity is multiplied by 2 when the number of represented poles is odd and different from 1 (ref.: FXM-15566)
No option to save the work after loss of license
Motor Factory 2022.3 does not give option to save the work after loss of license. (FXM-15557, FXM-15556).
Hairpin architecture
Solving tests or exporting projects to Flux is not allowed when the Hairpin winding is built with two layers. This will be fixed for the next version (ref.: FXM-15516)
Error with automatic connection between FluxMotor and HyperStudy
Sometimes, an error occurs when exporting/opening a connector several times in succession (ref.: FXM-15510).
Unable to execute test with Skew enabled in certain machine models (SMPM-OR)
Sometimes, for certain kind of machine, it is not possible to execute test with a skewed topology. In such cases, the error message contains the following message: “Please decrease the "Relative epsilon for distance between Points” (ref.: FXM-15475).
Export to FeMT with too long output path
The Flux script crashes when the output path for FeMT export is too long (ref.: FXM-15471).
Excel export does not work for the test Model - Maps
For the Synchronous machines with Permanent Magnets – SMPM (ref.: FXM-15465).
Fault in the coupling FluxMotor-HyperStudy
An error in the FluxMotor process doesn't stop the HyperStudy execution (ref.: FXM-15402).
ScriptFactory does not stop correctly
This occurs if the FluxMotor process has been killed externally. Then, ScriptFactory is not able to get back to a valid state, neither automatically, neither after a kill of the process (ref.: FXM-15140)
Bad meshing while representing wires inside the slots
When exporting a project from FluxMotor to Flux 2D, the mesh in the slot can be sometime very bad in the region surrounding the represented wires inside the coil conductors (ref.: FXM-15151).
Issue with exported Flux Skew projects
After exporting a Flux Skew project, if the user solves the project and delete the results and then solve again, the running of the project fails (ref.: FXM-15075).
Null values are not well managed while designing the Frame and shaft
Null values are allowed for designing the housing, bearing or shaft dimensions, but this leads to a wrong thermal analysis. It is highly recommended not to use null values for the considered inputs (ref.: FXM-14705).
Error while opening a motor (2020.1) with null shaft extension
Opening a motor built with the version 2020.1 (or older) with a null shaft extension leads to an error. With new versions, a null shaft extension is forbidden (ref.: FXM-14684).
The interwire space is not well defined
The resulting value of the interwire space applied in the finite element model is twice the value set in the user inputs (ref.: FXM-14672).
Air material properties are wrong for high temperature
Internal optimization processes can crash
Sometimes, when FluxMotor® launches an optimization in the back end with HyperStudy®, due to an error in the internal process (evaluation of the objective functions), FluxMotor® crashes.
Moreover, without any log file to explain the issue, one cannot understand the cause of system crash (ref.: FXM-13949).
When an IO cannot be loaded, the test results are not accessible
When an IO cannot be loaded, the whole process that loads all the test results is stopped. As a result, no test is visible although the issue may concern one result in a particular test (ref.: FXM-13941).
A wedge and/or inter-coil insulation region leads to a wrong slot equivalent thermal conductivity
The slot radial thermal conductivity, which is automatically provided by the FluxMotor® in "Cooling-Internal" context, and used in all thermal tests, is wrong if the slot contains faces "wedge" or "inter-coil insulator" (ref.: FXM-13896).
Power electronics and coupling with HyperStudy®
For tests where settings "Electronics" is available, data like power electronics stage, maximum efficiency and its rated power can be selected for generating a connector for HyperStudy®, but it should not be.
In the Export-HyperStudy® area, when the selected test is “Working Point, T-N”, the settings of “Electronics” - "Max efficiency", and "Rated Power" - are exported even if the associated option is not selected (ref.: FXM-13726).
Winding environment – MMF computation
The Counter-Clockwise sequence (MMF computation) is not considered in the Altair® Flux® model which one can export. Only the clockwise phase sequence is considered (ref.: FXM-10280).
Using "phase sequence" - set to "Counterclockwise" leads to wrong results in tests (ref.: FXM-13358).
Flux density isovalues
When a skewed topology is considered (Synchronous machines or induction machines), the flux density isovalues, the vector potential isolines and the rotor bars current density isovalues are not displayed (ref.: FXM-12564).
