A cooling system is used in high-pressure die casting to provide heat dissipation and to maintain a constant temperature
relative to the mold. This helps ensure tension-free cooling of the cast parts.
In High Pressure Die Casting, a shot sleeve is a piston sleeve that advances the
liquid in the chamber to the mold.
Simulate the fluid behavior inside the piston shot chamber during the first phase of
approximation in high Pressure die casting machines, and evaluate the possible
turbulences and the defects that it may cause in the part.
