SimLab Tutorial Summary: 2D SPM Motor Brushless
This tutorial shows how to use SimLab to design and run electromagnetic analysis with Flux solver for electric motors. The studied device, a brushless DC motor with surface permanent magnet, includes the following elements:
- a fixed part (stator) including yoke, slots, and windings
- an air gap
- a movable part (rotor) with surfaced magnets
In this tutorial, three typical transient magnetic analyses are defined to evaluate the motor performance:
- Analysis 1: Computation of the cogging torque
- Analysis 2: Back Electromotive Force
- Analysis 3: Constant speed
Example access
All files corresponding to this example are accessible in the Knowledge Base in Altair community:
- to follow the example step by step, the corresponding files are in
                            "Example_name_StepByStep" folder containing:- Tutorial folder: contains the document describing the example step by step
- InitialFiles folder: contains *.slb databases and files needed to build the example step by step
- to play scripts and retrieve SimLab and Flux project, the corresponding files
                    are in "Example_name_PlayScripts" folder containing:- ScriptsTutorial folder: contains script files to be able to play each analysis
- Input folder: contains initial *.slb databases and all necessary files to play each analysis script
- Output folder: empty (contains the obtained results after the script execution)
