Altair HyperCrash 2022.3 Release Notes
Enhancements
- Radioss keywords support
- Function scale factors have been added in /PROP/TYPE32.
- Model Checker
- The following checks are enhanced to consider Radioss /MERGE/RBODY keywords:
- Loose nodes of springs
- N1 not in rigid body
- N2 not in rigid body
- Rigid Body only on one Part
Resolved Issues
- Attributes of Radioss keyword /DAMP are now supported in unit conversion.
- The default value on “initial_mass_ratio” in Radioss keyword /DT/NODA has been corrected.
- Multiple issues have been fixed in the Joint tool in the Radioss profile.
- A correction has been made in reading LS-DYNA *MAT_RIGID when attribute values in CON1 or CON2 are left justified.
- A correction has been made in the LS-DYNA profile to maintain *ELEMENT_BEAM PID value for spotweld connections.
