Altair HyperForm 2022.3 Release Notes
Highlights
  • Panels are longer be available in HyperForm. All panel functionality can be found in HyperWorks.
Enhancements
RADIOSS One Step Profile
The OneStep Browser contains the following functionality updates:
  • Create new materials from the OneStep Browser's context menu.
  • Define Advanced panel settings from the OneStep Browser.
  • Autotip, Undercut Check, FLD Plots, Blank Shape, Load Results, Blank Fit, and Blank Nest panel functionalities are available on the OneStep Browser's context menu.
Additional Updates:
  • Circle Grid and Line Mapping panel functionalities are discontinued.
  • Inspire Form is recommended as an alternative for all advanced use cases/workflows.
Incremental – LS-DYNA
  • Tool Build panel functionality is supported in the Mesh > Thin Solids tool.
  • Create materials using the Model or Solver Browser.
Incremental – Radioss
  • The Trimming function, previously located on the Advanced panel, is located on the Tools menu.
