Altair HyperMesh 2022.3 Release Notes
Aeroelasticity
Resolved Issues
- Export of AERO entity for OS and Nastran solver formats has been fixed.
- RMB on sensor entity from the Browser for Crash and Ansys solver profiles showing "Edit MONPNT" has been resolved.
- Crash when MONPNT2 entity was wrongly defined with invalid elements has been resolved.
- Issue with RMB on some load collector type entities indicating "Create" twice has been resolved.
- F1 help for "Flutter curve plot" has been fixed.
Browsers
New Features
- Displayed Entities Count
- A Displayed Count context menu option has been added in the Model
Browser to check the count of displayed entities.Figure 1.Figure 2.
- Option to Close All Entity Views
- A Close Entity Views context menu option has been added in the Model
Browser to close all the entity-specific (flat) views at once.Figure 3.
- Option to Delete All Free/Preserved Nodes from the Model Browser
- All Free and Preserved nodes in the model can now be deleted using the
context menu options from the Nodes folder in the Model Browser.Figure 4.
Enhancements
- Attribute Columns for Geometric Entities
- Any attribute including metadata can now be added as a column in the
Points, Lines, Surfaces, and Solids entity views using the
Choose Attributes dialog or the Add column
option from EE.Figure 5.
- Element Configs in Choose Attribute Dialog
- Element config types are now shown in the Card/Config column in the
Choose Attribute dialog.Figure 6.
- Sub-Categories for Load Collectors in Abaqus Interface
- Load collectors are now organized into sub-categories in the Model
Browser under the Abaqus interface, to help in quick review.Figure 7.
- Isolate Entity Option in Browsers
- An Isolate Entity context menu option has been added in browsers. It can
be used to isolate within the selected entity type leaving the display
state of all other entity types as it is.Figure 8.
- Option to Create Tags from Model Browser
- Tags can now be created using the Model Browser context menu Create options.
- Added O Shortcut for Organize
- The Organize tool can now be invoked using the O keyboard shortcut after selecting an entity in the browser.
Known Issues
- The Entity Editor is not cleared when an entity is removed from the filtered browser list.
- The Keyword list for Create menu is removed from entity views upon loading a model.
Resolved Issues
- A performance issue while showing data in EE for load steps with multiple references has been resolved.
- A performance issue with opening Elements and Nodes Browsers has been resolved.
- A performance issue with invoking the context menu from the Loads folder in the Model Browser has been resolved.
- An issue with element type for RBE2 in attribute columns has been resolved.
Certification
Enhancements
- JointLoad method for fastener force extraction
- A new Resolved In option to extract forces in various systems is now available.
- Material system (default)
- Elemental system
- User system
Figure 9. - Run user method options
- The ability to create an output table per run or per loadcases is now available.
Resolved Issues
- Crash when creating marker shape (on Contour) using entity as nodeid is now resolved.
- Contouring result from large table (millions of rows) led to memory issue or took hours. To improve memory footprint, his issue is resolved in this release while contouring.
- To improve memory footprint, API *filtertable performance has been improved when flag allcolumns=0 is used.
Composites
New Features
- Material Reference Orientation Dialog
- Panel material orientation functionality has been migrated to the
Material Reference Orientation dialog. It can
be accessed from the context menu of the Composite Browser. There are
three tabs:
- Normals: to set shell element normals, which determine the laminate stacking direction.
- Reference Orientation: to set material reference orientation. All methods from the previous Aerospace Material Orientation dialog and panels are provided.
- Review: to review material reference orientation vectors.
Known Issues
- Ply Stacking Performance on Large Models
- If a large laminate is fully defined with a template property and plies which all have an assigned shape, performance while manipulating the stacking sequence by adding or removing plies or changing ply shapes may be slow. As a workaround, a ply with no assigned shape can be temporarily placed in the laminate and removed at the end of the stacking process.
Connectors
New Features
- Auto Fastener Connector
- An Auto Fastener tool has been added to pair holes and create connectors
to join them.Figure 13.
Enhancements
- Line Connector Enhancements
- Use the Imprint tool in the Connectors ribbon to imprint nodes as significant points to a line connector.
- Connector Control Enhancements
- Element type can now be set from CC or EE for standard realizations (for example, rigid, rod, and so on).
- Subsystem Hierarchy for Connectors
- Following the changes made to the hierarchy of subsystems, connector subsystems are assigned to the common parent subsystem of the connector's links.
- Eline Enhancements
- Impulse can now be specified with up to 3 decimal points.
- Aerospace Realizations
- The None option was added for Auxiliary points in RBE3-CBUSH-RBE3.
- Miscellaneous Enhancements
- Added support for joint elements in the feconfig file by using the joint keyword.
Design Explorer
New Features
- Property Design Variables
- A new type of design variable has been added where you can select elements or components in the model and allow their property assignment to become a variable within explorations. For example, you can choose a set of 1D elements and allow their section definition to be a variable.
- Design Variable Link Equations
- Design variable links have previously been limited to linking one or more variables to a main variable, ensuring that the linked variables’ value will be equal to the main value throughout the exploration. Now you can link variables using equations or combinations of variables. For example, a link could be created like variable3 = (variable1 + variable2/2).
- Generic Response
- The new Generic Response can be used to create responses based on a chosen reference solver output file. The enhancement allows you to potentially create responses which are not amongst the current set of out-of-the-box responses supported by Design Explorer.
- Run Nominal Run Only
- It is now possible to set up a DOE and run only its nominal run, which can be useful to check and debug the model or exploration prior to fully submitting the DOE for evaluation. To run only a nominal run, set the DOE Type to MELS and set the number of runs to 0.
- Apply Design Variables to Model
- Selecting this new option in the Results Explorer Summary Table will apply all design variable values for the selected run on the model.
- Clustering Enhancements
- Clustering uses unsupervised machine learning to group exploration
results according to user-specified criteria. Prior releases have
exposed limited clustering features in the Results Explorer Scatter Plot
tool. The updates to clustering include moving it to its own tool in the
Results Explorer, where you can now cluster based on load case and
result type of their choice. New enhanced visualization tools are
available, including the ability to visualize/animate all clusters,
overlay results for individual clusters, and create classifications,
which will be used via supervised machine learning in coming
releases.Restriction: Currently, clustering is only supported on Windows.
Design Space
New Features
- Exoskeleton Workflow
- Exoskeleton is a workflow that enables and promotes design exploration
of both early concepts and mature structures. The workflow provides
insight as to how the structure may need reinforcing to meet a
predetermined performance criteria. Two optimization approaches are
supported: Topology and Size. Both approaches use 1D elements tied to
the structure.Figure 14. TopologyFigure 15. Size
Extensions
New Features
- Pre-Defined Registration of Multiple Extensions Via an Environment Variable
- To start HyperWorks with a pre-defined set of extensions, you can now
set the environment variable HWX_PLUGINS to add one
or more directories from which all extensions will be registered. Click
Remove to disable these extensions.Figure 16.
Enhancements
- Block the Disabling of Extensions
- The Remove button can be disabled by adding the removable keyword,
<entry name="removable" value="true"/>
, in the general section of the extension.xml file. - Improved Error Messages
- Meaningful error messages are displayed and the extension is not loaded when a ribbon xml is not referenced from inside a profile in the extension.xml file or when tags are not matching.
Resolved Issues
- The issue with ribbons and toolbars of some extensions not disappearing after an extension has been disabled has been resolved.
Known Issues
- Loading extensions covering pre and post-profiles with the HyperMesh profile active will not show the extension loaded in the post clients. The extension needs to be enabled in at least one of the post clients. Similarly, the extension needs to be loaded in the HyperMesh profile if it was loaded first in one of the post profiles.
General
New Features
- Multi-Model
- It is now possible to have multiple HyperMesh pre-processing windows active within the session, each with its own model. This removes the need to have multiple copies of the application open and reduces memory overhead.
- Miscellaneous
- A Copy IDs option has been added to the context menu under . This will copy the ID range to the clipboard.
- Drag/Drop
- A dialog now opens when you drag-and-drop a file into HyperMesh. You can
open or import any file type using this method. Multi-model loading is
not supported.Figure 17.
- Create Set
- The Create Set option has been added to the context menu for Nodes &
Element selection in OptiStruct, Radioss, Abaqus, ADVC, LS-DYNA, and
Permas. This is supported in idle and the Organize tool.Figure 18.Figure 19.
- Find Tool
- The Find tool is now available in the View Toolbar. Use the Find tool to
find and display other entities based on their connectivity or proximity
to the selected entities. Choose between the Attached to, Nearby, and
Shared by functions.Figure 20.
- Mass Validation Tool
- The Mass Validation Tool has been enhanced with following new
functionalities available from the hamburger menu:Figure 21.
- Option for COG and MOI calculation in user defined coordinate system.
- Option for MOI calculation around selected coordinate system center.
- Option for the consideration of Lumped Mass in COG and MOI calculation (only in LS-DYNA and Radioss profiles).
- Options to show the calculated COG on the graphic and create a Node at the COG location.
- Option to change the numerical format and precision of the values exposed in the GUI.
Enhancements
- Move Tool
- Orient the selected direction using the Vector tool. Hold Ctrl and select three points to define the direction by plane.
- Use the + / - buttons to apply an incremental translation or rotation in the selected direction.
- The vector magnitude is automatically input as the increment for translations.
Figure 22. - Vector Tool
- Select a Vector entity to align to, or assign a local coordinate
System.Figure 23.
- Plane Tool
- Input the Plane center coordinates in the manipulator microdialog.Figure 24.
Known Issues
- Known issues for the File
Open/Save dialogs and Message boxes:
- There are inconsistencies in the appearance of the File Open and File Save dialogs and Message boxes.
- Based on how they are opened and the available file extension filters in the File Open and Save dialogs, the appearance/style of the dialog can differ from other instances.
- Some of these dialogs can move behind the main application when clicking elsewhere in the application. This requires you to bring them to the foreground or reposition the application.
- Figure 25 and Figure 26 show examples of different versions of the
File Open dialog:Figure 25.Figure 26.
- HyperWorks can hang on re-launch in following instances: if the license is
close to expiring, when the license expiration warning dialog opens, and if
a non-default browser was active on shutdown.
- To avoid this, one of the following environment variables can be
used:
- ALM_NO_EXPIRE_WARNING: Disables the expiration warning.
- ALM_EXPIRE_DAY_WARNING: Specifies the number of days before license expiration, the warning message is given (default is 30).
- If one of the environment variables listed above is not used to avoid this issue and the issue occurs, deleting the settings files will resolve the issue.
used:
- In some cases involving multi-monitor setups, if a browser or dialog is dragged from one monitor to another, associated context menus can appear outside the browser/dialog, potentially even on the original monitor.
- When running in a NICE/DCV environment, there are drawing issues with the HWx toolbelt.
- On Linux, an error can be seen when importing/opening files from a directory with a name/path containing non-ASCII characters. This error can be avoided by using the encoding system utf-8 command, either in a script or by manually typing it into the Tcl console, before importing/opening the file(s).
Resolved Issues
- Issues involving some dialogs (Parameter/Criteria Editor, Advanced Selection dialog, and so on) not being visible in certain multi-monitor configurations have been resolved.
- Performance issues associated with show, hide, and isolate have been resolved.
- Crash associated with importing an HyperMesh model on top of an existing model has been resolved.
- Performance issue while opening and switching ribbons has been resolved.
- Performance issue with invoking the graphics context menu for large models has been resolved.
- Optionally turn off Move Tool preview to improve the performance with large models.
Geometry
New Features
- Create Ribs Tool
- The Create Ribs tool has been added under the Geometry Create pull-down menu.
- Find Symmetry Tool
- The Find Symmetry tool has been added under the Geometry Cleanup pull-down menu.
- Arc Line Creation Tool
- The Arc Line Creation tool has been added under Geometry - Shapes.
Enhancements
- Free (Temp) Nodes and Preserve Nodes Functionality
- Free (temp) nodes and preserve nodes functionality has been added under the Nodes/Points Create tool.
- New Create Mesh Option
- A create mesh option for surface patch/ruled/drag/spin to create geometry with mesh was added.
- Parametric Creation
- ParamFree etric creation of nodes and interpolate nodes functionality was added under the Nodes/Point Create tool.
- Parametric Line Creation
- Parametric line creation was added under the Lines tool.
Matrix Browser
Resolved Issues
- System selection is now considered correctly when querying results through Matrix.
- An issue with application crashes when referencing columns with labels containing special characters in the equation definition has been resolved.
Meshing
New Features
- Align/Project Tool
- The Align/Project tool has been added in the Elements ribbon.Figure 27.
- Beam Section Contexts
- New beam section contexts have been added in the Mesh Page for all solver profiles.
- Shrink Wrap
- Shrink wrap has been added under pull-down menu.
- Acoustic Cavity
- Acoustic Cavity has been added under pull-down menu.
- SPH
- SPH has been added under pull-down menu.
Enhancements
- FE Geometry Creation on Duplicating Elements
- If copied elements are orphan mesh, the output is orphan mesh.
- Edit Element Tools
- Significant performance improvements have been made for Edit element tools.
- QI Color Mode is Optional
- QI color mode has been made optional. The default is OFF for all Edit element tools.
- Edit Elements Split Tool
- Edit Elements Split tool supports standalone 1D splitting.
Resolved Issues
- 1D Stiffener meshing for Marine applications: generation of 1D stiffener mesh from orphan lines is up to 30x faster on large ship models.
Model Build
New Features
- Display Representation
- A new lightweight visualization mode of geometry is supported for CAD
formats. Supported geometry file formats are: Acis, Catia, CatiaV6,
Creo, Inspire, Inventor, JT, Rhino, NX native, NX third party,
Parasolid, SLDPRT/SLDASM, STEP, and VDAFS.Figure 30. Import GeometryFigure 31. Import BOM
- OpenPDM Connection
- New PDM Connector, OpenPDM, is now supported. OpenPDM facilitates the better flow of information between different PLM systems. By using OpenPDM connector, HyperMesh can work with any PLM system that integrates with OpenPDM seamlessly.
- Classify Tool
- The Classify tool, a machine learning tool, has been added in the new
AI/ML section of the Assembly ribbon. This tool exploits the benefits of
machine learning (ML) to auto-assign labels to parts based on their
shape. Each label starts out being manually created and assigned by the
user to help the ML model learn what parts look like. Once you have
assigned Labels using your own data, you train a model which can then be
used to Classify parts on new models. The goal is to automate the
process of part identification and classification to reduce manual
effort of organizing a large model.Figure 32.
- New Curve Editor
- The Curve Editor has been upgraded and given a new look to support some additional features. Tables in the Curve Editor now supports import of tabular data from csv files, direct export to csv, manipulation of data inside a table, such as inserting or deleting rows anywhere in the table, and copy and paste from within or from outside, without any limitations. Curve operations are also supported, such as duplicate a curve, hide, show or isolate a curve with the right-click context menu, Fit all function in the right-click context menu or keyboard shortcut F, and search and filter curve names from within the Curve Editor.
- Renumber All
- The Renumber All method has been added to the Renumber tool. With this option, all entities of all types in the model are renumbered at once.
Enhancements
- Save Representation Workflow Updates
- The save representation workflow has been enhanced by allowing the save
of only modified parts. Modifications to parts are tracked so we can
automatically only save the parts that need saving.Figure 33.
- Sections and Sensor Entities Saved into Part Representations
- Sections and Sensor entities are saved into part representations, which better supports Ansys workflows.
- Saving Representations Performance Improvements
- Performance enhancements have been made to improve the time taken to save representations.
- Default Settings Updated for the RBE3 Tool
- The default settings of the RBE3 tool have been updated so that the weighting coefficients for independent DOF are a constant 1.0. The distance-weighted coefficient method is still available to use in the tool, but it is no longer the default.
Resolved Issues
Slowdowns with selection and renumbering of large models in the Renumber tool have been resolved.
Model Verification
Enhancements
- Shape AI Digital Signature Calculation
- Shape AI Digital Signature Calculation added for Part Match function and stores the calculated value in Part attributes.
- Intersection Database File
- Intersection Database file can be created from previous ran Intersection results, file will contain Digital Signature, BBOX attributes, XYZ intersection location information for all the Parts.
- Intersection Check Function
- Intersection Check function reads Part's Database (Digital Signature,
BBOX attributes, XYZ intersection locations), compares it with Variant
model's attributes and segregates Intersection Reports to Filtered and
Non_Filtered groups. If the Part's BBOX, Digital Signature, Intersection
Locations are compared with Variant Part's attributes, if the comparison
results are within limit set in configuration, then its reports is
organized to Filtered Group.Figure 34.
- Intersection Automatic Renumbering of Parts
- Intersection will automatically renumber parts if duplicate PID exist, it takes max ID + increment.
- Log Information
- All log information are unified to have PIDs for Comparison.
Resolved Issues
- Configuration File: Exporting Configuration file pointing to the :C drive instead of the working directory has been fixed.
- Intersection Report: No entities found in Sphere creation error has been fixed.
- Quick comparison no longer fails for certain JT assembly model.
- Spot Extraction no longer fails for certain JT model.
Morphing
Enhancements
- Panel Migration into Controllers
- Figure 35.
- Morph Volumes
- The Main-Secondary Tangency arrow direction has now been updated to point from Main to Secondary. Historically, it would point from Secondary to Main.
Resolved Issues
- Corrected issue with "on elems" in morph constraint, "maintain" and "along vector" options, projecting erratically.
Plots
New Features
- Chart Entity
- It is now possible to create and edit charts for visualization purposes. The Chart entity type has been added.
Known Issues
- For Chart entities, the direct input table does not record a tcl command. This will be added in upcoming releases. For automation, the Matrix table option can be used.
Post
New Features
- Marker Plot
- Results plots can now be requested in the form of text on the screen,
also known as Marker plots. Just like contour, vector, and tensor plots,
Marker plots store a result definition and list of entities.
- A mini legend that comes with Marker plots indicates the currently plotted result in the marker.
- It can be overlaid with any other plot type.
- Basic manipulation of text such as text color, show hide, and multi line is supported.
Enhancements
- Result Query Tools
- Exposed via GUI through
- Derived Loadcase Workflow
- The derived loadcase workflow has been enhanced. Some of the notable
updates are:
- Support for Envelope-Extreme loadcase.
- Layer/System/Averaging method and Corner Data can be specified when defining Envelope metric.
- Delete or rename Derived loadcases from Results Browser.
- Review Derived loadcase definition in Entity Editor.
- Category Based Legends for Contour Plot
- A category based legend will now be displayed for the following types of
contour plots:
- MaxLayer or MinLayer
- Envelope Trace (Subcase/Step/Sorner/Layer/Resource)
- Contact Status (OS/Abaqus)
- Contour Plot Performance Improvement
- The performance of the Contour Plot has been improved.
Resolved Issues
- Incorrect material system is no longer used for solid elements.
- Application no longer crashes when plotting thermal gradient vector results with corner data from Ansys result files.
- Application no longer crashes when trying to plot tensor on file with no tensor data types.
- Application no longer crashes when contour and deformed plots are present and the divergent option is selected from graphics legend context menu.
Safety Tools
Enhancements
- IP Impact Post Processing Tool
- Support of Pamcrash solver:Figure 37.
Resolved Issues
- IP Impact Pre-processing Tool:
- Pamcrash: Correction of exported set in the impactor positioning file to avoid duplicated nodes.
- When marking the IP with Automatic marking process, the move back angle value on the impact points is now set to 0.3 degree.
- Seatbelt tool:
- Radioss: Correction of the density value in the default /MAT/FABRIC when unit system (mm, s, Mg) is selected.
- Radioss: Seatbelt tensioning is now working when dummy is encrypted.
- Mechanism and Dummy:
- Import of model having duplicated IDs in Mechanism and Dummy metadata has been corrected.
Solver Conversion
Enhancements
- Ansys to OptiStruct Conversion
- SURF153/SHELL208 was converted to CONM2.
- Abaqus to OptiStruct Conversion
- Penta,COH3D6/15 was converted to Penta,CIFPEN6/15.
- Dyna to OptiStruct Conversion
- BOUNDARY PRESCRIBED MOTION was converted to SPCD.
CAD and Solver Interfaces
Abaqus Interface
Enhancements
- Migrated Loads Support
- Support for migrated loads through Pretension manager was enhanced.
- New Keyword
- A new keyword was added: *INELASTIC HEAT FRACTION.
- New Element Type
- A new element type was added for heat transfer: C3D6HT.
- Modelchecker
- Overconstraint check for dependent nodes in coupling constrains was added.
Resolved Issues
- Duplicate names for sets no longer have an issue with renumbering and renaming.
- New dataline added for *CAVITY DEFINITION to have more than two surfaces.
- Property definition on compound sets across includes was lost in export and the issue is resolved.
- The keyword *GAP no longer has missing data, such as slip rate or friction coefficient.
- Search issue with *FLUID BEHAVIOR has been resolved. It will now will lead to the right material card.
- An issue with Entity State Browser on export/active status for migrated keywords (*NON-STRUCTURAL MASS, *RIGID BODY) has been resolved.
- An issue with the keyword *CONTACT INTERFERENCE importing wrong surfaces with input file import has been resolved.
CAD Interface
Enhancements
- Updated Version Support (Readers)
- Inventor 2023
LS-DYNA Interface
New Features
- New LS-DYNA Solver Profile R13.1
Enhancements
- Keyword Migration to New Entity
- *CONSTRAINED_JOINT_STIFFNESS_(OPTIONS) keywords are migrated from the Property entity to the Constraint entity.
- New Supported Keywords
- Constrained: *CONSTRAINED_JOINT_STIFFNESS_CYLINDRICAL
- Keywords Updates Till R13.1 Version
- Airbags: New attributes added in *DEFINE_CPM_VENT.
- LS-DYNA I10 Format
- Support of long=s in *KEYWORD along with i10=y. Long=s can be added via the solver deck export options when i10 format is activated.
- Performances
- Relevant performance improvements made in the Model Checker.
Resolved Issues
- A correction has been made in the Position/Transformation tool when Positions are applied or un-applied. Only selected Position is now affected and performances are improved.
- Card4 in *MAT_SEATBELT_2D is now treated as optional.
- Export issue of *CONTROL_MPP_DECOMPOSITION_TRANSFORMATION has been fixed.
- Multiple corrections have been made in reading and editing *MAT_3-PARAMETER_BARLAT_(OPTIONS). Anisotropy axis definition attributes are read and maintained on export independently from the AOPT value.
- A correction in reading *MAT_ORTHOTROPIC_ELASTIC has been made. Anisotropy axis definition attributes are read and maintained on export independently from the AOPT value.
- A correction in reading *MAT_LAMINATED_COMPOSITE_FABRIC has been made. AOPT value wasn't read properly.
- A correction in reading *SENSOR_SWITCH_CALC-LOGIC has been made.
- *ELEMENT_SPH attributes are now fully exposed in the Entity Editor.
- Show/Hide/Isolate/Review operations are now working on Position entity when defined on *INCLUDE_TRANSFORM.
Nastran Interface
Enhancements
- Moved Super Elements Creation Process
- Super elements creation has been moved from the panel to the controller workflow in the Elements ribbon.
- Drive Mapping Support
- Drive Mapping is now supported on Export of solver decks, enabling you to work with solver decks across operating systems.
Resolved Issues
- Load (superposition) not allowing selection of other Load entities has been resolved.
- Export performance delay while exporting model with spring elements has been resolved.
OptiStruct Interface
Enhancements
- Moved OptiStruct Thermal Cards
- OptiStruct thermal cards have been moved to the appropriate HyperMesh
entities for ease of thermal analysis setup.
Card From HyperMesh Entity Type To HyperMesh Entity Type CHBDYE Groups Set Segment CONV Groups Load PCONV Groups Property - Set Entity
- Set entity has been enhanced to support BOOLEAN operator subtype in SET_GRID and SET_ELEM set types.
- Moved OSSMOOTH
- OSSMOOTH has been moved from the panel to the controller workflow in the Optimize ribbon.
- Moved Gauge and Shape Optimization Setup
- Gauge and Shape optimization setup has been moved from the panel to the controller workflow in the Optimization ribbon.
Resolved Issues
- Issue where you were unable to select a subcase for STATSUB(BUCK) through the Entity Editor has been resolved.
- Issue where PACPML's node id was missing in the exported OptiStruct input file has been resolved.
- Issue with the wrong vector fields export for GRIDCON in DSHAPE card with vertex option has been resolved.
- Issue with deletion of pretension surf from browser cause application in pretension manager has been resolved.
- Issue with incorrect export of SN line in MATFAT definition has been resolved.
- Issue with user comments not being written for PLY card on export has been resolved.
- Issue with component information being lost while importing input file with plane strain element definition has been resolved.
PAM-CRASH Interface
New Features
- Modular Material MMAT 2020
- New MMAT 2020 is now supported along with Legacy MMAT.
- Mechanism Tool
- The Mechanism tool is now exposed in PAM-CRASH interface.Figure 38.
Enhancements
- Group Entity Selection Improvements
- Selectors of entities in the Group Entity Editor (Contact, Mass_GES & NSMAS) are now only with 'Set' selector.
Resolved Issues
- Mass calculation results for the NSMAS and NSMAS2 keywords have been corrected when MLEN, MARE, and MVOL parameters are defined.
Permas Interface
Enhancements
- New Set Segment Entity
- The $SURFACE and $SURFACE GEO cards have been migrated from contact surface to setsegment.
Radioss Interface
Enhancements
- New supported keywords: /FAIL/GENE1, /FAIL/RTCL, /FAIL/SAHRAEI, /H3D/SPH/(OPTION), /MAT/101, /MAT/LAW121, /SURF/ELLIPS.
- Updated Keywords
- There are new attributes in /LOAD/PBLAST.
- Performances
