Use the Volume Mesh tool to define local volume mesh sizes on individual solids. You can also choose different volume mesh settings,
such as defining layers on thin regions and quality controls.
Use the Extrusion tool to create hex mesh on extruded geometry. This is useful for creating mesh for 2D simulations
and layered mesh on simplified geometry.
Use the Zones tool to define mesh refinement settings by shape. These controls provide the capability to get mesh refinement on
surfaces enclosed in defined boxes, spheres, and cylinders.
on individual solids. You can also choose different volume mesh settings, such as defining
These controls will not change the defined surface mesh controls; you must assign
controls to solid body surfaces according to the sizes defined here.
From the Mesh ribbon, click the Volume Mesh tool.
Select solids.
In the dialog, define volume mesh options.
Select Propagate size to surface mesh to pass on the
volume mesh control settings to all the surfaces of the selected solids. If you
already defined surface mesh controls for those solids, the smaller size between
the surface mesh control and the volume mesh control is enforced.
From the guide bar, execute the command in the following
ways:
Click to confirm your selection and remain in the
tool.
This allows you to continue creating instances and helps you
visualize and edit instances with the legend.
Click to confirm your selection and exit the
tool.
