Analytical Rigid Surfaces
The Abaqus solver offers the flexibility of modeling rigids as surfaces using primitive geometry.
Simplicity of modeling is the primary advantage of using this feature.
- can be 2D or 3D
 - can be swept or revolved geometry
 - can be used with the small-sliding, or finite-sliding mechanical contact formulations
 - should be oriented in such a way that the surface's outward normal of the surface points toward any part it may contact
 - is associated with a node, known as the rigid body reference node, whose motion governs the motion of the surface
- Selecting/defining a local system
 - Choosing 2D or 3D and within 3D sweep or revolve
 - Choosing lines or a node path to define the feature in the chosen local plane to complete the analytical rigid surface set-up
To access the tool, navigate to the Model ribbon, click the arrow next to the Interactions tool set name, then select Analytical Rigid.
