Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction,
transforming results, defining material orientation, and many other operations.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on
the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type,
the tool generates contacts based on set segments or node and element combinations.
Scenarios are a mechanism to apply controls to engineering entities.
The Scenario Manager allows you to define a scenario with a name
and solver profile. Within the scenario, you can then create a series of definitions
comprised of rules and corresponding controls in a specific order. The order of the
definitions determines how the controls are applied.
When applied, the scenario evaluates the rules in the order defined. If an
engineering entity successfully meets the rule requirement, it has a control
applied. Any engineering entity that doesn’t meet the rule requirement is moved to
the next definition for evaluation. If any engineering entity successfully has a
control applied, it is excluded from any later definition.
From the Assembly ribbon, click the
Scenario tool.
Upon opening the Scenario Manager, an initial
scenario is already available.
Optional: Right-click on a scenario to duplicate, rename, change the solver interface, or
delete.
The solver interface filters the available controls. This ensures that the
scenario is in a single solver.
Figure 3.
Click to create additional scenarios.
Figure 4.
Click in the active scenario tab to create new definitions.
Figure 5.
Similar to scenarios, right-click on a definition to rename, review, control
the display, and delete.
Select the desired control to be applied to the engineering entity.
For connectors, the type of control automatically filters what type of
connectors the control applies to. This is because the controls are explicitly
related to a specific type (Points/Lines/Areas/Fasteners).
Right-click on Rule column and select
Edit. Use the Rule Builder to
dynamically determine which engineering entities that a given control is applied
to.
The rule can be created based on Data on the engineering entity, by Shapes, by
Selection, or All.
Figure 6.
Click / to reorder the definitions so they will be
evaluated in a different sequence.
Optional: Choose whether or not to realize the entities after the control is
applied.
When applying a control, define how it will respect local changes on the
Overwrite Attributes
Overwrite all local values on the engineering entity.
Keep Local Values
Keep all local values on the engineering entity.
Respect Local Overwrite Attributes Flag
Respect the Local Attribute flag on the engineering entity.
Click Apply to apply the definitions to the current
entity within the scenario or click Apply All to apply
all definitions for all the entities within the scenario.
Tip: Click to
open a saved scenario. Click to
save all scenarios and definitions, and optionally:
