mdlIObject AddSystemFromDefInMemory
Adds a system from an existing definition.
mdlIObject_handle AddSystemFromDefInMemory new_handle, varname, label, existing_def_name
MotionView Tcl Modify
This command adds a new system from an existing definition in memory. The required input to create a System from definition in memory, apart from ‘label’ and ‘varname’, is an already existing definition name (existing_def_name). The ‘existing_def_name’ should be present in memory. In other words, a System with definition name as ‘existing_def_name’ should already be added into the Model.
- new_handle
 - The handle of the newly created system.
 - varname
 - The variable name for the new system.
 - label
 - The label for the new system.
 - existing_def_name
 - The existing system definition name which will be used to create the new system.
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName AddSystemFromNewInlinedDef new_handle System sys_0 "\"SYSTEM 0\"" def_sys_1
myModelName AddSystemFromDefInMemory sys_handle sys_1 "\"SYSTEM 0\"" def_sys_1
sys_handle ReleaseHandle
new_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleErrors
Returns the handle of the newly created system if successful. If there is an error, an error code will be returned.
