mdlIObject GetSourceFile
Obtains information about the source file for the assembly created in the model.
mdlIObject_Handle GetSourceFile type
MotionView Tcl Query
This command obtains information about the source file for the assembly created in the model.
- type
 - The type of source file requested. Valid arguments are: DATA and DEFINITION.
You need to load an assembly prior to running this example.
To get the source file of a given assembly:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle myAssembly assem_0
set temp [myAssembly GetSourceFile DATA];
tk_messageBox -message "The Source of the Assembly is: $temp";
myAssembly ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns the file name including the path and Library name.
