mdlIObject AddSystemFromImportedInlinedDef
Adds a new system from an existing definition file.
mdlIObject_handle AddSystemFromImportedInlinedDef new_handle, varname, label, existing_file_path, existing_def_name
MotionView Tcl Modify
This command adds a new System using an existing definition. The definition should be present in a file which will be provided as the argument ‘existing_file_path’. The file ‘existing_file_path’ should have the same definition name as ‘existing_def_name’ in order to create the System successfully.
- new_handle
 - The handle of the newly created system.
 - varname
 - The variable name for the system which will be created.
 - label
 - The label for the system.
 - existing_file_path
 - The path of the existing external system file.
 - existing_def_name
 - The definition name of the system. The name should be the same as the ‘existing_file_path’ name.
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetObjectHandle obj_handle
obj_handle AddSystemFromImportedInlinedDef tmp_handle sys_1 "\"SYSTEM 1\"" C:/temp/system.mdl def_sys_0
tmp_handle ReleaseHandle;
obj_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleErrors
Returns the handle of the newly created system if successful. If there is an error, an error code will be returned.
