mdlIObject OutlineGraphic
Highlights the outline of a graphic for visual identification of that particular graphic.
mdlIObject_handle OutlineGraphic outline_state
MotionView Tcl Query
Use this command to check and verify graphics. When executed, this command will outline the requested graphic allowing you to identify it in the graphics area.
- outline_state
 - Asks whether or not the outline is to be highlighted.
- True
 - The outline will be identified and highlighted.
 - False
 - The outline will not be highlighted.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName BeginFlatListFastGet Graphic
myModelName GetChildHandleByIdx graphic_handle 2
graphic_handle OutlineGraphic True
graphic_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
