Driver Overview
The Altair Driver is a set of MotionView models and libraries that allows MotionView users to control and script vehicle events.
- Constant Radius Cornering
 - Single Lane Change
 - Double Lane Change
 - User Defined Path Following
 - Fish Hook Event, etc.
- Steering
 - Throttle
 - Gear
 - Brake
 - Clutch
- Scripting - break up the simulation into different maneuvers; select the controllers for vehicle inputs and define conditions that end each maneuver.
 - Open-loop, closed-loop, and user-defined controllers to control.
- Longitudinal speed or acceleration.
 - Vehicle path or lateral acceleration.
 - Switching controllers during a simulation.
 - Defining path and speed profiles parametrically, in a table, or by referencing a data file.
Architecturally, the Altair Driver is a cluster of signal manager, controller library, and controller manager.
| Controller | Logical unit of the driver computes outputs for given inputs. |
| Controller Library | Library of the available controllers. |
| Controller Manager | Parses through the Script, Altair Driver File (ADF). This manager does this
                    following:
| Signal Manager |
| End Condition Sensor | Monitors the end conditions and switches the maneuver when the end condition is true. |
